So, the question is: Is the concept of a function contravariant?
  • Context: Graduate
  • Thread starter Thread starter Troponin
    Contravariant Function
The discussion revolves around the concept of whether the notion of a function, particularly in the context of differential forms, is contravariant. Participants explore the implications of this classification within the framework of differential geometry and category theory.
  • One participant describes how a map from a vector space to its dual space defines a function that transforms contravariantly, suggesting that 0-forms (functions) are contravariant.
  • Another participant notes that the function can be expressed as a linear combination of a basis, with coefficients that transform contravariantly.
  • A different viewpoint emphasizes that while the differential of a function belongs to the dual space, the function itself does not, leading to a discussion about the relationship between functions and their differentials in terms of covariance and contravariance.
  • One participant introduces category theory, explaining that the classification of functors as covariant or contravariant depends on the direction of associated homomorphisms relative to differentiable functions between manifolds.
  • It is proposed that certain mathematical structures, like the cotangent bundle and sheaf of scalar fields, are contravariant, while others, such as the set of curves, are covariant.
Participants express differing views on the classification of functions as contravariant or covariant, with no consensus reached on the definitions or implications of these terms in the context of differential forms.
The discussion involves nuanced interpretations of mathematical concepts, including the definitions of contravariance and covariance, and the relationships between functions and their differentials. Some assumptions about the nature of these transformations remain implicit and unresolved.
Troponin
My understanding of differential forms is that, given the map
[tex]\phi : V \to V^{*}[/tex]
If [tex]f \in V^{*}[/tex] is a 0-form (a real-valued function on [tex]V^{*}[/tex]), then [tex]\phi[/tex] defines the function [tex]\phi^{*} f[/tex] on [tex]V[/tex]
where [tex]\phi^{*}: F^{0}(V^{*}) \to F^{0}(V)[/tex]
as the function such that [tex]\phi^{*}f(p)=f(\phi(p))[/tex].
So, since differential forms transform contravariantly, the 0-form (function) f transforms contravariantly (and therefore is contravariant...).
Because [tex]f[/tex] doesn't have any indices, I decided to look online and see if that fact makes a difference in requiring the label "contravariant."
One of the first links was to a thread on physicsforums
https://www.physicsforums.com/showthread.php?t=311174
The debate is between "dx" and "MarkParis." It doesn't seem to reach an agreement in that thread, so I was wondering if anyone else could shed some light on it.
*IMO, the posts by "dx" are correct and meet my understanding of the topic. However, I'm still learning differential forms and there is certainly going to be nuances of the subject that I haven't understood yet...so I figured I'd see if anyone here has any input on this and/or the posts made in the linked thread.
The function f belongs to V*, so it can be expanded in a linear combination of a basis of V*. The coefficients of this expansion form a vector, that transforms contravariantly.
I think MarkParis's point is that strictly speaking it is df belongs to V*, not f itself.
Similarly it is d/dl that belong to V, not the curve itself.
And Hurkyl and dx's points are that df comes from f, just as d/dl comes from the curve, so in that sense f is "contravariant" while a curve is "covariant" (or is it the other way round, I never remember which is which).
The unifying notion of covariant and contravaraint comes from category theory.
There are lots of things we might be inclined to associate to any particular manifold -- things like its tangent bundle, the cotangent bundle, the set of curves defined on the manifold, its homology groups, et cetera.
Each of the things I mentioned above is a "functor", which here boils down to saying that if you have a differentiable function between manifolds, then you get a homomorphism between the kinds of things we are associating to the manifold.
The functor is covariant if the associated homomorphism goes in the same direction as the differentiable function, and contravariant otherwise. e.g. "Cotangent bundle" is contravariant, because for any differentiable function f:M-->N, the map f*:T*N-->T*M goes in the same direction.
Similarly "the set of curves" is covariant, because given f:M-->N, the associated function on the set of curves (i.e. "composition with f") turns a curve on M into a curve on N.
In this sense, "the sheaf of scalar fields" is contravariant, as is the "set of differentiable functions to R".
  • · Replies 20 ·
  • · Replies 36 ·
