Is this Spring Damper System effective?
The discussion centers on the effectiveness of a Spring/Friction Damper system when the damping coefficient (B) exceeds the spring stiffness (A). It is established that the system will still function, as stiffness and damping serve different roles: stiffness resists deflection while damping resists velocity. The conversation emphasizes the importance of understanding the units of measurement for both properties, as they cannot be directly compared. Additionally, the term "work" requires clarification to fully assess the system's performance.
  • Understanding of mechanical systems, specifically Spring/Friction Damper systems
  • Knowledge of stiffness and damping coefficients
  • Familiarity with units of measurement in mechanics
  • Basic concepts of torque and its effects on mechanical systems
  • Research the principles of Spring/Friction Damper systems in mechanical engineering
  • Explore the relationship between stiffness and damping in dynamic systems
  • Learn about the mathematical modeling of mechanical systems using differential equations
  • Investigate the impact of varying damping ratios on system performance
Mechanical engineers, students studying dynamics, and professionals involved in the design and analysis of mechanical systems will benefit from this discussion.
skyuen9
A real simple question but need confirmation:
When I have a simple Spring/ Friction Damper system where the value of the spring stiffness is say A(Nm) and the Damping is B(Nm). If the value is B > A, will the Spring system still work? Or will the spring just keep still no matter what the input torque is?
A stiffness and damping coefficient don't, and can't have the same units. Stiffness is a property which resists deflection or displacement while damping resists velocity. Check your units again.
Also...what does "work" mean?
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 31 ·
  • · Replies 0 ·
