Mechanism for compensatory RESPIRATORY acidosis caused by metabolic alkalosis?
  • Context: Medical
  • Thread starter Thread starter shredder666
    Mechanism
The discussion centers on the mechanism of compensatory respiratory acidosis resulting from metabolic alkalosis. Participants explore the physiological processes involved, including the roles of chemoreceptors, respiratory rate, and kidney function, as well as the implications for blood pH regulation.
  • Some participants propose that slowed respiratory rate is a key mechanism, where chemoreceptors in the carotid bodies detect changes in blood CO2 levels, leading to decreased respiration and CO2 retention.
  • Others argue that the kidneys also contribute by excreting more bicarbonate when they are not the primary cause of metabolic alkalosis.
  • A participant notes that descriptions of metabolic alkalosis with respiratory acidosis can be misleading, suggesting it is better to describe it as metabolic alkalosis with partial respiratory compensation.
  • One participant emphasizes the rapid response of the lungs in regulating blood pH through changes in ventilation, contrasting it with the slower response of the kidneys.
  • There is a discussion about the biochemical reaction involving CO2, water, bicarbonate, and H ions, highlighting how changes in CO2 levels can influence blood pH.
Participants express varying views on the mechanisms involved in compensatory respiratory acidosis and the roles of the lungs and kidneys, indicating that multiple competing perspectives remain without consensus.
Some limitations include the dependence on specific physiological definitions and the complexity of acid-base balance, which may not be fully resolved in the discussion.
shredder666
mechanism for compensatory RESPIRATORY acidosis caused by metabolic alkalosis?
I don't get it... someone please explain :(
Biology news on Phys.org
It's mostly from slowed respiratory rate. Chemoreceptors lining the blood vessels, especially the carotid bodies detect blood CO2 levels. The decreased partial pressure of CO2 will cause these bodies to send less stimulatory signals to the respiratory center in the medulla which leads to decreased respiration rate and retention of more CO2 (which becomes carbonic acid in the blood). **edit, the carotid bodies detect H+ concentration, not CO2 partial pressure directly.
Take this with a grain of salt as I'm only an undergrad who's read Guyton & Halls Physiology text a few times.
This is essentially correct in terms of compensation for metabolic alkalosis. The kidneys also pitch in by excreting more bicarbonate when they are not the primary cause of metabolic alkalosis (via loss of H ions). BTW, the frequently used descriptions metabolic alkalosis with respiratory acidosis, or metabolic acidosis with respiratory alkalosis are somewhat misleading. The patient is either acidotic or alkalotic if not normal. It's better IMO to say metabolic alkalosis with partial respiratory compensation, etc.
Causes of metabolic alkalosis are due to anything that causes loss of extracellular H ions (such as excessive vomiting or low extracellular potassium causing a shift of H ions into the intracellular compartment in exchange for potassium) or excess bicarbonate. One of the unfortunate causes of this is excess bicarbonate administration in the treatment of acute keto or lactic acidosis in diabetics.
Metabolic alkalosis results in a depletion of blood H ions right - leaving blood pH higher than normal. Enzymes don't like the pH being off in the slightest - it affects their function - it affects the function of all proteins and all processes. Therefore there is a rapid way to get more H ions into the blood and correct pH. Slow breathing down - by reducing ventilation the partial pressure of CO2 builds up in blood - Co2 and water form bicarbonate and importantly for blood pH - a H ion. So now blood pH comes back down to normal pH. People generally consider the kidney when we talk of acid base control - but actually kidney takes hours to days to change function. the lungs by changinf ventilation can rapidly change blood ph. Slow ventilation - increase CO2 and acidify blood. Increase ventilation - blow off CO2 and reduced the H ion concentration.
All linked to
CO2 + H2O - H+ and HCO3-
by changing CO2 we drive the reaction forward or back. And hence compensate for any change in blood pH.
  • · Replies 30 ·
  • · Replies 22 ·
10K
