Thread Closed
Find the molecular mass of acid in acid base neutralization
Share Thread Thread Tools
Sep25-10, 08:28 PM   #1
1.5000 g of diprotic weak acid H2A was dissolved in 100.00 mL volumetric flask.
25.00 mL aliqouts of this solution was titrated with a monoprotic strong base NaOH (0.08000 M). The titre volume of NaOH was 40.00 mL. Calculate the molecular weight of H2A.
2. Relevant equations
N/A
3. The attempt at a solution
1 mole of H2A contains 2 moles of H+
1 mole of NaOH contains 1 mole of OH-
2CaVa = CbVb
2 (Ca)(0.02500 L) = (0.0800 M)(0.04000L)
Ca = 0.0640 M
#moles of H2A = CaVa
= (0.0640 M)(0.10000 L)
= 0.00640 mol
molecular mass of H2A = mass/# moles
= 1.5000 g / 0.00640 mol
= 234.375 g/mol
My answer is 234.375 but something seems odd about it. Can anyone tell me if I missed something or did something wrong? Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep26-10, 10:49 AM   #2
Admin
Quote by jessica.so View Post
2CaVa = CbVb
Question is - is that 2 in the correct place?
www.titrations.info, www.chemistry-quizzes.info, www.ph-meter.info
Sep26-10, 11:03 AM   #3
I've always been taught that the exponent in CaVa = CbVb equations is the number of moles of H[SUP]+[SUP] ions or OH[SUP]-[SUP] ions which is why I put the 2 infront of the CaVa.
Another time I attempted this question but I balanced the neutralization first.
H2A + 2 NaOH --> 2 H2O + Na2A
CaVa = 2 CbVb
(Ca)(0.02500 L) = 2(0.0800 M)(0.04000L)
Ca = 0.256 M
= (0.256 M)(0.10000 L)
= 0.0256 mol
= 1.5000 g / 0.0256 mol
= 58.59 g/mol
This answer seemed wrong too somehow. One of the questions that came up was that the acid we are neutralizing is a weak acid. 25mL of this weak acid was neutralized by 40mL of strong base. Shouldn't a weak acid take less base to neutralize?
Sep26-10, 11:24 AM   #4
Admin
Exponent? I guess you mean stoichiometric coefficient. But you were right the first time, somehow I got it reversed.
Now, the problem is - 0.00640 moles - is it whole 1.5 g sample?
Strength of the acid has nothing to do with amount of base that it needs to be neutralized. It is all in stoichiometry.
Sep26-10, 11:36 AM   #5
So sorry! Yes, I did mean the coefficient.
So...I'm using the first attempt...
2CaVa = CbVb
2(Ca)(0.02500 L) = (0.0800 M)(0.04000L)
Ca = 0.0640 M
= 0.00640 mol
= 234.375 g/mol
So I found the molarity of the H2A that was neutralized. Because a 25.00 mL sample was taken from the 100.00 mL solution, the molarity stays the same. 1.5000 g made the 100.00 mL solution of H2A so I think the 0.00640 mol is the whole 1.5 g sample.
Sep26-10, 11:55 AM   #6
Admin
have you titrated 100 mL aliquot?
Sep26-10, 12:32 PM   #7
No, I have not titrated 100mL
Thread Closed
Thread Tools
Similar Threads for: Find the molecular mass of acid in acid base neutralization
Thread Forum Replies
Weak acid/strong base titration (Acetic acid/NaOH) Biology, Chemistry & Other Homework 4
calculating molecular mass of oxalic acid (diprotic acid) using only given #s? Biology, Chemistry & Other Homework 1
Neutralization (Acid-Base) Reaction Chemistry 1
Non 1:1 Ratio in Acid-Base Neutralization Chemistry 9
Acid-Base neutralization w/ more than 1 base. Chemistry 6
