Question about terminal velocity
The discussion centers on calculating the terminal velocity of an object with a weight of 4 N and a drag coefficient of 3 N·s²/m. The correct approach involves equating the weight (W) to the drag force (bv²) to find the terminal velocity. The solution provided indicates that the terminal velocity is approximately 1.15 m/s. This method is validated by the principle that at terminal velocity, the net force acting on the object is zero, resulting in no further acceleration.
  • Understanding of Newton's second law of motion
  • Familiarity with drag force concepts in physics
  • Basic algebra for solving equations
  • Knowledge of terminal velocity principles
  • Study the relationship between weight and drag force in free fall scenarios
  • Explore advanced topics in fluid dynamics related to drag coefficients
  • Learn about the effects of varying drag coefficients on terminal velocity
  • Investigate real-world applications of terminal velocity in different contexts
Students studying physics, educators teaching mechanics, and anyone interested in understanding motion under the influence of forces.
preluderacer
An object of weight W falls from rest subject to a frictional drag force bv^2. What maximum ("terminal") velocity will it approach if W = 4 N and b = 3 N∙ s2/m?
I set W = Bv^2 and solved for v and got 1.15. I am not quite sure if this was the method of doing this. Some insight would be nice.
Yeah, at the point where the drag force equals the weight, the net force on the object will be zero, meaning that it will no longer accelerate (by Newton's second law). Hence, it continues to fall at a constant velocity, the terminal velocity.
That's why equating the two forces is the method used to solve the problem.
Thank you, sometimes I am able to solve problems, but can't explain why!
