How do I solve a surface charge problem for a cylindrical drum?
  • Thread starter Thread starter pulser45
    Charge Surface
The discussion focuses on calculating the surface charge on a cylindrical drum used in copy machines, specifically a drum that is 40 cm long with a radius of 5 cm. The electric field near the surface is given as 2 x 10^5 N/C. The correct approach involves using the formula Q = σ * 2πrL, where σ is the surface charge density, and equating the electric field E to σ/ε0. Participants clarify that the charge density can be derived from the electric field using the relationship σ = E * ε0, leading to the total charge calculation.
  • Understanding of electric fields and charge density
  • Familiarity with Gaussian surfaces in electrostatics
  • Knowledge of the relationship between electric flux and charge (Q = E * ε0)
  • Basic proficiency in algebra for manipulating equations
  • Study the derivation of electric field equations for cylindrical conductors
  • Learn about Gaussian surfaces and their applications in electrostatics
  • Explore the concept of electric flux and its relation to charge density
  • Investigate common pitfalls in online homework systems for physics problems
Students in physics courses, particularly those studying electromagnetism, educators teaching electrostatics, and anyone involved in solving problems related to electric fields and charge distributions.
pulser45
Hi, I need help with a surface charge problem:
The cylindrical drum of a copy machine is 40 cm long and has a radius of 5 cm. If charge is uniformly distributed over the curved surface of the drum, and the electric field near the surface is 2 x 10^5 N/C, estimate the amount of charge on the drum.
I know you set the electric flux to Q/E0. I calculated the Q = o*2pi*r*L. Since electric flux E(2*pi*r*L) should cancel out 2pi*r*L when setting them both equally, leaving E=o/E0. However, i still keep getting the wrong answer. Thanks for the help.
It looks ok to me. You probably used your Gaussian surface (cilinder) having the same radius as the cilinder itself, because you know the field very near the surface. This way you can cancel the r's, giving o=E/E0.
So multipy the charge density by the surface area to get the total charge.
Alternatively, you could've used E(2*pi*r*L)=Q/E0
and plug in the numbers immediately to find Q.
Wouldn't o=E*E0 ? So i would just multiply o by 2*pi*r*L and I would be fine?
My professor adopted this online homework website from ilrn. IMHO, its horrible, because it will only accept the exact answer that was entered. No partial credit given at all because you don't even show your work. Thanks.
  • · Replies 35 ·
  • · Replies 26 ·
