Calculating Geostationary Orbit for a 700kg Meterological Satellite
  • Thread starter Thread starter josephcollins
    Orbits Satellite
The discussion revolves around calculating parameters for a geostationary orbit of a 700kg meteorological satellite, including the radius of the orbit, linear speed, and energy required for launch. The context involves applying principles of orbital mechanics and gravitational physics.
  • The original poster attempts to apply Kepler's laws and gravitational equations to find the radius, speed, and energy for the satellite's orbit. Some participants question the calculations and suggest verifying the results through alternative methods.
Participants are actively engaging with the calculations, with some providing guidance on verifying results and considering additional factors such as work done against gravity and initial kinetic energy. There is no explicit consensus on the correctness of the calculations presented.
The discussion includes assumptions about gravitational acceleration and the radius of the Earth, as well as the period of revolution for the satellite. There is an emphasis on checking values and considering various aspects of the problem without providing direct solutions.
josephcollins
Hi people, could someone please help with these:
On 19th June 1981, an experimental meterological satellite of mass m=700kg, was placed in a geostationary orbit using the launch vehicle Ariane.
Calculate:
i. The radius of the geostationary orbit given that the period of revolution of the satellite is 23h 56m.
ii. The linear speed of such a satellite.
iii.The energy required to move the satellite from the surface of the Earth into the geostationary orbit.
Thanks a lot
What have you done so far with the problems?
I used Kepler's law that the cube of the radius of the Earth is proportional to the time of orbit's square, I hope this will work, knowing g=9.8Nkg-1, the mass of the satellite 700kg, the orbit period 86160s and the radius of the Earth 6.37 *10^6. I got an answer of 4.2 *10^7 m. Can someone verify this please?
Then for part 2 I used the formula v=(g*R^2/r)^1/2 with r as the radius of the orbit and R as the radius of the Earth, g equals 9.8Nkg-1. I got 3072.3 ms-1, is this correct?
To put this satellite in orbit I used Ek=(mv^2)/2 to get 3.3*10^9 J.
I'd be grateful if you could check these values. Cheers
For the second part, if you know the radius of the orbit then you know the distance it travels in 1 day (circumference of the circle) so just divide by the number of seconds to get the speed. You can use this to check your answer!
To put the satellite into orbit you also should consider the work done against gravity to lift the satellite. You might also want to consider the initial kinetic energy of the satellite before launch due to the rotation of the Earth.
