Contradicting Effective Potentials for Kepler's Problem
  • Context: Graduate
  • Thread starter Thread starter gitano
    Potentials
The discussion centers on the effective potential in Kepler's problem, specifically the discrepancy arising when substituting angular velocity into the Lagrangian. The correct effective potential is given by U_{eff}(r) = U(r) + \frac{M_{z}^{2}}{2mr^{2}}, while an erroneous form U_{eff}(r) = U(r) - \frac{M_{z}^{2}}{2mr^{2}} is derived incorrectly. The key insight is that when suppressing a coordinate through a conserved momentum, the Lagrangian is not invariant, necessitating the use of the Routhian to obtain the correct equations of motion. The Routhian is defined as R = -T + U_{eff}.
  • Understanding of Kepler's problem and angular momentum conservation
  • Familiarity with Lagrangian mechanics and its formulations
  • Knowledge of effective potentials in classical mechanics
  • Concept of the Routhian and its application in dynamics
  • Study the derivation of effective potentials in classical mechanics
  • Learn about the Routhian and its significance in Lagrangian dynamics
  • Explore the implications of cyclic coordinates in Lagrangian mechanics
  • Review Section 3.4 of the provided dynamics resource for deeper insights
Students and professionals in physics, particularly those focusing on classical mechanics, Lagrangian dynamics, and celestial mechanics. This discussion is beneficial for anyone looking to clarify the application of conserved quantities in Lagrangian formulations.
gitano
Hi,
I have a question that has been bothering me for a while now. For Kepler's problem we know that angular momentum [tex]M_{z}[/tex] is conserved and that the angular velocity [tex]\frac{d\phi}{dt}[/tex] is equal to [tex]\frac{M_{z}}{mr^{2}}[/tex]. When we substitute for [tex]\frac{d\phi}{dt}[/tex] in the expression for energy, we get an effective potential
[tex]U_{eff}(r) = U(r) + \frac{M_{z}^{2}}{2mr^{2}}[/tex],
which is correct.
However, when we substitute this into the Lagrangian, one of the signs changes and we arrive at an erroneous effective potential
[tex]U_{eff}(r) = U(r) -\frac{M_{z}^{2}}{2mr^{2}}[/tex]
which is clearly wrong. There must be some subtlety which I am overlooking that explains why you can't substitute this expression into the Lagrangian and arrive at the correct effective potential, or for that matter the correct Lagrangian.
I am also curious that if in general you can express a generalized coordinate in terms of a constant of motion (the coordinate is cyclic) is it also wrong then to make such a substitution in the Lagrangian as is incorrect in the Kepler problem.
Hi,
have a look at this: http://www.aerostudents.com/files/dynamicsAndStability/lagrangianDynamics.pdf"
Section 3.4 has your answer: when suppressing a coordinate through a conserved momentum, the Lagrangian is not invariant, you have to use the Routhian (actually if you change its sign, things look better) to transform the Lagrangian so that its Euler-Lagrange equations are the equation of motion
Routhian will turn out to be R=-T+Ueff (the correct Ueff)
Hope this helps
  • · Replies 0 ·
