Reducing the Order of a Cauchy-Euler Equation
  • Thread starter Thread starter Juanriq
    Chain Chain rule
The discussion focuses on reducing the order of a Cauchy-Euler equation, specifically addressing the transformation of derivatives using the chain rule. The user attempts to express the second derivative with respect to x in terms of t, utilizing the relationships x = e^t and ln x = t. The key insight provided is the application of the chain rule, leading to the formulation of the derivative as d/dx = (1/x)(d/dt), which clarifies the user's confusion regarding the transformation of dy/dt.
  • Understanding of Cauchy-Euler equations
  • Familiarity with the chain rule in calculus
  • Knowledge of derivatives and their transformations
  • Basic concepts of exponential and logarithmic functions
  • Study the derivation of Cauchy-Euler equations in detail
  • Explore advanced applications of the chain rule in calculus
  • Learn about differential equations and their solutions
  • Investigate the relationship between exponential functions and their derivatives
Students studying differential equations, mathematics educators, and anyone seeking to deepen their understanding of Cauchy-Euler equations and derivative transformations.
Juanriq
Reduce the order of a Cauchy-Euler Equation
[itex]x = e^t \mbox{ and } \ln x = t[/itex]
[itex]\displaystyle \frac{d y}{d x} = \displaystyle \frac{d y}{d t} \displaystyle \frac{d t}{d x} = \displaystyle \frac{d y}{d t} \cdot \displaystyle \frac{1}{x}[/itex]
and thus
[itex] \displaystyle \frac{d^2 y}{d x^2} = \displaystyle \frac{d y}{d t} \cdot \displaystyle \frac{-1}{x^2} + \displaystyle \frac{1}{x} \displaystyle \frac{d}{d x} \Bigl ( \displaystyle \frac{d y}{d t} \Bigl )[/itex]
Here is where I am getting stuck, specifically on [itex]\displaystyle \frac{d}{d x} \Bigl ( \displaystyle \frac{d y}{d t} \Bigl )[/itex] this step. I know what I should get...
[itex] \displaystyle \frac{1}{x} \Bigl ( \displaystyle \frac{d^2 y}{d t^2} \cdot \displaystyle \frac{1}{x} \Bigl )[/itex]
But uhhh not getting it. Thanks in advance!
You apply the chain rule again, except instead of applying it to y, you're applying it to dy/dt. It's a bit clearer if you look at it in terms of operators:
[tex]\frac{d}{dx} f = \frac{dt}{dx}\frac{d}{dt} f = \frac{1}{x}\frac{d}{dt} f[/tex]
so
[tex]\frac{d}{dx} = \frac{1}{x} \frac{d}{dt}[/tex]
Ahhh...very nice! Thanks a bunch!
  • · Replies 34 ·
