Using Bisection Method to Find Points of Intersection for y=x^3-2x+1 and y=x^2
The discussion revolves around finding the points of intersection between the curves defined by the equations y=x^3-2x+1 and y=x^2, specifically using the bisection method.
  • Exploratory, Problem interpretation
  • Participants explore how to apply the bisection method to identify points of intersection, with suggestions to derive an equation from the difference of the two curves.
The discussion includes attempts to clarify how to set up the problem for the bisection method. One participant indicates they have resolved their question, but no explicit consensus or final solution has been reached among all participants.
Participants reference the requirement to use the bisection method, and there is an emphasis on deriving an equation from the given curves to facilitate this process.
gomes.
[itex]y=x^3-2x+1[/itex]
[itex]y=x^2[/itex]
The question says to use the bisection method to find the points of intersection of the 2 curves. I know how to use the bisection method to find the root of an equation (like on this page http://kr.cs.ait.ac.th/~radok/math/mat7/step7.htm ), but how would I use it to find the point of intersection? Thanks.
Well let [tex](x_i,y_i)[/tex] be a point of intersection. Can you use those curves to derive an equation for which either [tex]x_i[/tex] or [tex]y_i[/tex] is a root?
What do you get if you subtract one equation from the other?
thanks, I've solved it now :)
  • · Replies 27 ·
