Are You Struggling to Understand Reference Frames in Relativistic Dynamics?
The discussion revolves around understanding reference frames in the context of relativistic dynamics, particularly focusing on the transformation of four-velocity and four-force between different inertial frames. The original poster expresses confusion about how different observers perceive the motion of a particle and the implications for calculations involving Lorentz transformations.
  • The original poster attempts to clarify the relationship between the four-velocity, four-force, and the velocities observed in different frames. They raise questions about the appropriate use of the Lorentz factor and the implications of different reference frames on calculations.
  • Some participants question the assumptions regarding which velocities should be used in the Lorentz factor and how these relate to the observed velocities in different frames.
  • Others suggest that the context determines which velocity is relevant for calculations involving the Lorentz factor.
The discussion is ongoing, with participants providing insights and clarifications regarding the use of velocities in different contexts. There is an exploration of the nuances involved in transforming quantities between frames, and some guidance has been offered regarding the appropriate use of the Lorentz factor in various scenarios.
Participants note that the original poster's confusion may stem from the complexity of relativistic dynamics and the multiple reference frames involved in particle motion. There is an acknowledgment of the need to solidify understanding of these concepts without reaching a definitive conclusion.
kreil
Insights Author
I'm having trouble getting all of the relativistic dynamics information straight in my head. In particular, I'm having trouble with reference frames. It seems that when I am trying to solve problems, even simple ones, I am struggling with what each observer in the different frames should be seeing.
For example, let's say in the rest frame O an observer sees a particle moving with velocity V. The particle has a four velocity given by (note: I use c=1 units everywhere)
[tex]\bar u = \frac{d \vec x}{d \tau} = (\gamma, \gamma \vec V)[/tex]
and the four force on the particle would be
[tex]\bar f = \gamma (\vec F \cdot \vec V, \vec F)[/tex]
Now let's say an observer in the frame O', moving with velocity v along the x-axis of O, observes the particle. From the velocity law, he sees the particle moving at speed:
[tex]V^{x'} = \frac{V^x-v}{1-vV^x}[/tex]
where [itex]V^x[/itex] is the observed velocity in O.Question: Is it true that the particle's four velocity and four force are transformed to use this [itex]V^{x'}[/itex] ? Why or Why not?
Question: Is the velocity in the Lorentz Factor [itex]\gamma[/itex] the velocity of the particle in the rest frame V, or the relative velocity between the frames v?
Question: Is it correct to say that for any problem where a particle's velocity is being observed there are 3 reference frames to worry about: the rest frame O, the moving frame O', and the frame of the particle? If it is relevant, I encountered these thought problems while trying to find the four force and four velocity components for a particle moving in the Lorentz Force Field (Hartle problem 5.21),
[tex]\vec F = \frac{d \vec p}{dt} = q(\vec E + \vec V \times \vec B)[/tex]
which is invariant between inertial frames.
I realize that this is all quite basic stuff math wise, but the thought process that leads to the correct calculations is giving me trouble, and it is crucial I get it solidified into my head correctly.
Yes, of course. In O', the only thing you see is the particle's three-velocity Vx'. The four-velocity and four-force aren't going to depend on quantities observed in a different frame. After all, there would be an infinite number of frames you could choose from, right? Which one would you pick?
If you're calculating the four-force or four-velocity in O', you'd use neither. You'd use the three-velocity of the particle as observed in O'. Is this what you were asking about? Your question seemed a bit ambiguous.
Not for any problem. In particle physics, sometimes you can do an entire problem in the lab frame; sometimes, it's convenient to use a center-of-mass frame, where none of the particles is at rest; sometimes, you find the particle's rest frame a convenient choice. If you're working with massless particles, like photons, there is no rest frame (of the particle).
The lorentz factor is,
[tex]\gamma = \frac{1}{\sqrt{1-v^2}}[/tex] in units of c=1.
My question related to the fact that many things get multiplied by this gamma factor: Lorentz Coordinate Transformations, four-velocity, etc.. but is the velocity in gamma always the same? i.e. Are we using the velocity between frames in gamma for the Lorentz Transformations, but the three-velocity in gamma when calculating the four-velocity?
No, the appropriate velocity in γ depends on the context. For the four-velocity, it is the velocity of the particle. For a Lorentz boost, it's the velocity of the moving frame.
Thanks vela, you've been helpful as usual!
Just to make sure I understand, is this correct?
"Assume that in all frames the force on a charged particle is given by the lorentz force law (given above). Consider a frame moving with speed v along the x-axis relative to the lab frame. Find the components of the 4-force in terms of E, B and the components of the 4 velocity."Assume the particles velocity is [itex]V'=\frac{V-v}{1-Vv}[/itex] as observed from the moving frame. Then,
[tex] \bar f' = \gamma (\vec F \cdot \vec V', \vec F)[/tex]
[tex]\vec F \cdot \vec V' = q(\vec E + \vec V' \times \vec B) \cdot \vec V'=q|E||V'|cos 0 =qEV'[/tex]
because V'xB is perpendicular to V' their dot product is zero.
[tex]\bar f' = \frac{q}{\sqrt{1-\vec V'^2}} \left [ EV', (\vec E + \vec V' \times \vec B) \right ][/tex]
and since,
[tex]\bar u' = \frac{1}{\sqrt{1-\vec V'^2}} ( 1, \vec V' ) = ( \vec u_{t'}, \vec u_{x'})[/tex]
we get:
[tex]\bar f' = q\left [ E \vec u_{x'}, (\vec E \vec u_{t'} + \vec u_{x'} \times \vec B) \right ][/tex]
You're assuming the electric field and velocity point in the same direction. If you don't assume that, the best you can do is say that
[tex]\vec{F}\cdot\vec{V}' = q\vec{E}\cdot\vec{V}'[/tex]
