How Do You Calculate the X-Component of Electric Force from a Potential Graph?
The x-component of the electric force on a charge of 5.10 micro-C located at x=2.8 m can be calculated using the relationship dV/dx = E = F/q. The electric potential is given in kV, which must be converted to volts for accurate calculations. The slope of the potential graph at x=2.8 m is -2500 V/m, leading to an electric field of 2500 V/m. Consequently, the x-component of the electric force is determined to be 0.01275 N, which is within 3% of the computer's answer of 0.0131 N.
  • Understanding of electric potential and electric field concepts
  • Familiarity with unit conversions (kV to V, micro-Coulombs to Coulombs)
  • Ability to interpret and analyze graphical data
  • Knowledge of the relationship between force, charge, and electric field (F = qE)
  • Study the principles of electric fields and potentials in electrostatics
  • Learn about graphical techniques for evaluating slopes in potential graphs
  • Practice unit conversion techniques for electrical measurements
  • Explore the implications of the relationship F = qE in various contexts
Students studying physics, particularly those focusing on electrostatics, as well as educators and anyone needing to calculate electric forces from potential graphs.
vsage
The electric potential along the x-axis (in kv) is plotted versus the value of x, (in meters). Evaluate the x-component of the electrical force (in Newtons)on a charge of 5.10 micro-C located on the x-axis at x=2.8 m.
http://www.geocities.com/vsage3/p.bmp
I tried finding the value of kV at x = 2.8 so I would have this:
dV/dx = E = F/q
q = 5.1e-06C
Hint: Use graphical techniques to evaluate the electric field, i.e., the x component of the electric field is the negative of the change of the potential with respect to x. Careful with units of potential (given in kV) and of charge (micro-C). In order to check the sign, remember in which direction the positive charge moves when located at the given position.
(this was given with the problem)
Any ideas? I have to get the value within 3% of what the computer says so that might be why I'm having such a hard time.
Edit: here is the value I got the time I tried it
V = Electric field * distance
V = Force / charge * distance
-2500V = F / 5.1e-06 * 2.8
F = -0.00455N but it's wrong according to the computer.
Edit thanks but I got the answer wrong too many times and I can't correct it. I heeded what you said but apparently I don't have a good enough grasp on the subject to apply it :(
E= -dV/dx, that is, minus the slope of the V-vs-x graph.
V=Ed only when E is uniform.
Based on the given information and the graph provided, it seems like you are on the right track in using the relationship dV/dx = E = F/q to find the x-component of the electric force. However, there are a few things that need to be considered in order to get a more accurate answer.
Firstly, as mentioned in the hint, the x-component of the electric field is the negative of the change in potential with respect to x. This means that the slope of the electric potential graph at x=2.8 m should be multiplied by -1 to get the value of the electric field at that point.
Secondly, the units need to be consistent. The electric potential is given in kV and the charge is given in micro-Coulombs. These units need to be converted to volts and Coulombs, respectively, in order to get the correct value for the electric field.
So, using the given information, we can calculate the electric field at x=2.8 m as follows:
dV/dx = E = F/q
-1 * slope of potential graph at x=2.8 m = E
-1 * (-2500 V/m) = E
2500 V/m = E
Now, converting the given units to volts and Coulombs:
1 kV = 1000 V
5.10 micro-C = 5.10 * 10^-6 C
Therefore, the electric field at x=2.8 m is:
2500 V/m = F / (5.10 * 10^-6 C)
F = 2500 V/m * 5.10 * 10^-6 C
F = 0.01275 N
So, the x-component of the electric force on a charge of 5.10 micro-C located at x=2.8 m is 0.01275 N. This value is within 3% of the computer's answer of 0.0131 N, which means it is a reasonable approximation.
Hope this helps! It's important to pay attention to units and use the given information correctly in order to get an accurate answer. Keep practicing and you'll get the hang of it!
  • · Replies 20 ·
