How Does the Propagator Relate to the Heat Kernel on a Manifold?
The discussion centers on the relationship between the propagator of a scalar field and the heat kernel on a manifold, specifically using the Laplacian operator D. The heat kernel is defined as K(x,y;s) = ⟨x | exp(-sD) | y⟩, where s represents diffusion time. The propagator is expressed as D^{-1}(x,y) = ∫₀^{∞} ds K(x,y;s). The inquiry seeks a method to derive the heat kernel from a given propagator, with the conclusion that inverting the propagator may yield the operator D, allowing for the reconstruction of the heat kernel.
  • Understanding of Laplacian operators on manifolds
  • Familiarity with heat equations and heat kernels
  • Knowledge of scalar field theory and propagators
  • Basic concepts of functional analysis and operator theory
  • Research the properties of heat kernels on Riemannian manifolds
  • Study the inversion of operators in functional analysis
  • Explore the relationship between propagators and Green's functions
  • Learn about the spectral theory of differential operators
Mathematicians, theoretical physicists, and students studying differential geometry, particularly those interested in the interplay between heat equations and quantum field theory.
Orbb
Hi,
I have a question about the relation between the propagator of a scalar field and the heat kernel. I'm not sure wether I should rather put this question into the math section: Given a Laplacian D on some manifold M, what I mean by heat kernel is just
[tex]K(x,y;s) = \langle x | \exp(-sD) | y \rangle[/tex]
where x, y are distinct points on M and s is the diffusion time (in the sense that K obeys the heat eqn.). Now the propagator of a scalar field can be determined from K via
[tex]D^{-1}(x,y) = \int_0^{\infty} ds K(x,y;s).[/tex]
What I want to ask now is wether there is a way to invert this expression such that given some propagator, I can determine the corresponding heat kernel. Can anyobdy help?
Cheers,
O
Really no one with a hint? Is the question somehow ill-posed? Or should I add more detail about the specific calculation I am attempting?
Just a guess here:
The propagator is the inverse of the operator D. So if you were given the propagator, and invert it, you would get back the operator. From there, you should be able to construct your heat kernel.
  • · Replies 0 ·
