Thermodynamics: Cyclic Processes
The forum discussion focuses on solving a thermodynamics problem involving a cyclic process for 1 mol of an ideal monoatomic gas. The process consists of an adiabatic expansion, an isobaric compression, and an isochoric return to the original state. Key calculations include determining the final temperature (T3 = 231.36 K), work done during each phase, and changes in internal energy. The discussion highlights the importance of using the correct equations, such as the adiabatic process equation (PV^γ = C) and the relationship between work and heat transfer (Q = W).
  • Understanding of the ideal gas law (PV = nRT)
  • Knowledge of thermodynamic processes: adiabatic, isobaric, and isochoric
  • Familiarity with heat capacities (Cv and Cp) for monoatomic gases
  • Ability to apply the first law of thermodynamics (ΔEint = Q - W)
  • Study the derivation and application of the adiabatic process equation (PV^γ = C)
  • Learn about the implications of the first law of thermodynamics in cyclic processes
  • Explore the differences between heat capacities (Cv and Cp) for various types of gases
  • Practice solving thermodynamic problems involving cyclic processes and internal energy changes
Students and professionals in physics and engineering, particularly those studying thermodynamics, as well as anyone involved in solving complex gas behavior problems in cyclic processes.
Archy
Thermodynamics: Cyclic Processes (solved)
Sorry for the false alarm guys. It looked like I did use the wrong equation while finding the internal energy for case 1.
referred to this. Thanks.
https://www.physicsforums.com/showthread.php?t=412577
Given that
1 mol of ideal monoatomic gas at p= 1 atm undergoes a three step process:
1) Adiabetical expansion from T1=550K to T2=389K
2) Compression at constant pressure until T=T3
3) Return to original pressure and temperature by a constant-volume process
Find
a. T3
b. Change in internal energy, work done and heat added to the gas for each process
c. Change in internal energy, work done by the gas and heat added for a complete cycle
Q=W
PV=nRT
T1V1γ-1=T2V2γ-1
p=1.013x105
mol= 1 mol
Given monoatomic gas, therefore f=3
Cv=f/2R=3/2(8.31)=12.465 J mol-1 K-1
Cp=Cv+R= 20.775 J mol-1 K-1
γ=Cp/Cv=5/3
for a.
By process,
1) Under adiabatic expansion (ΔQ=0)
Using PV=nRT
then V1=nRT1/P=0.04512 m3
Using T1V1γ-1=T2V2γ-1
therefore V2γ-1=T1V1γ-1/T2
therefore V2= (T1V12/3/T2)3/2= 0.07586 m3
therefore P2=nRT/v2=4.2613x104Pa
3) Under Isovolumetric process (ΔV=0; ΔW=0)
Q= nCvΔT
P2=P3=4.2613x104Pa since 2) is an isobaric process
P4=1.013x105
T4=550K
Using PV=nRT; ΔV=0
then V3=V4
then nRT3/P3=nRT4/P4
therefore, T3=T4P3/P4=231.3638K
That aside, my real problem is in question b, actually
for b.
By process,
1) ΔEint=-W under adiabatic process,
I think that under this condition, W should probably be
[PLAIN]http://www.texify.com/img/%5Cnormalsize%5C%21%5Cdisplaystyle%20W%3D%20%5Cint_%7BVi%7D%5E%7BVf%7D%20%5Cfrac%20%7BnR%28T_2-T_1%29%7DV.gif
But I'm not sure of it's validity.
Anyway eventually it'll lead to W=nR(389-550)(ln 0.07586-ln 0.04512)=-695.1298J
Which I doubt is correct.
2) Under isobaric process (ΔP=0); T3=231.3638K
W=nRΔT=(8.31)(231.3638-389)J=-1309.9568J
Q=nCpΔT=(20.775)(231.3638-389)=-3274.8921J
ΔEint=Q-W=-1964.9353J
3) ΔV=0; W=0
Since W=0
then ΔEint=Q=nCvΔT=(12.465)(550-231.3638)=3971.8Jc.
Since the whole thing is a cyclical process,
W=Q
which also means
W-Q=0 or the cumulative ΔEint=0
I can't answer this one because,
after adding all the ΔEint it appears that it's not 0.
So. Problem there. I still suspect is 1) that's causing the trouble.
Help there?
Also, if you may, please do look through the workings to see if there are any faults in there. Thank you.
Yeah, your work seems fine other than part 1). Though, I cannot attest to your numbers, maybe setting your straight for the adiabatic process will fix it.
[tex]PV^\gamma = C[/tex]
[tex]W=\int P dV[/tex]
[tex]W = \int C V^{- \gamma} dV[/tex]
[tex]W = \frac{1}{- \gamma + 1} (CV_2^{-\gamma +1}- CV_1^{-\gamma +1})[/tex]
we know that
[tex]P_1 V_1^\gamma = C = P_2 V_2^\gamma[/tex]
so plug it in for C in the right spots
[tex]W_{adi}=\frac{1}{1-\gamma}(P_2 V_2 - P_1 V_1)[/tex]
P.S. I am always getting my sign confused and have to rely on physical intuition to get it right, so don't trust my sign.
Ohh. So that's how that formula came about.
Hmm. I actually used W= -nCvΔT? It worked sufficiently, in a surprising way.
But I was wondering how, since V1 and V2 are obviously not the same and Cv is the heat capacity at constant volume?
Thanks for the reply though. Really helpful.
  • · Replies 19 ·
