Statistics Help-Joint pmf and marginal pmfs
The discussion focuses on finding the joint probability mass function (pmf) of two independent and identically distributed (iid) discrete uniform random variables, X1 and X2, defined on the integers {1, 2, 3, ..., n}. The joint pmf is derived from the maximum (Y = max(X1, X2)) and minimum (W = min(X1, X2)) of these variables. Participants suggest visualizing the problem using a 2D lattice to understand the distribution of values and probabilities, emphasizing the importance of considering specific cases to formulate a general solution.
  • Understanding of discrete uniform random variables
  • Familiarity with joint and marginal probability mass functions
  • Basic knowledge of probability theory and combinatorics
  • Ability to visualize data in a 2D lattice format
  • Study the derivation of joint pmfs for discrete random variables
  • Learn about the properties of iid random variables
  • Explore combinatorial techniques for calculating probabilities
  • Practice plotting joint distributions on a 2D lattice
Students studying probability theory, statisticians working with discrete distributions, and educators teaching concepts related to joint and marginal pmfs.
runner4life
Statistics Help--Joint pmf and marginal pmfs
Let X1 and X2 be iid discrete uniform random variables with support on the integers {1,2,3,...,n}.
Find the joint pmf of Y=max(X1,X2) and W=min(X1, X2).
Find the marginal pmf's of W and Y
I need help on how to set this problem up. the max and min is throwing me off.
so imagine the variables as forming a 2D lattice, each of the lattice points having equal probability
as always consdier a few cases to get going
max(x1,x2) = 1, can only be (1,1)
max(x1,x2) = 2, can be (2,1), (2,2), (1,2)
max(x1,x2) = 3, can be (3,1), (3,2) (3,3), (3,1), (3,2)
this form should give you a hint on how to work out a generic formula
to understand why this formula works, try plotting the points on your lattic & see where they fall
