Register to reply
A question about standard metric cube
by exergetic
Tags: cube, metric, standard
Share this thread:
exergetic
#1
Nov23-10, 01:21 PM
P: 11
Hi everybody,
I'm having difficulties sizing a compressor for natural gas.
First,my assumption is to take natural gas as mixture of ideal gases.The compression must be between 9 and 32 bar and it starts at 45 C.
I know that volumetric flow rate must be 85000 Sm3 per day ,where I assume 15C and 1 bar as Standard Conditions.
Now how do I think about volumetric flow rate considering conditions of the fluid inside the compressor?
Do I need to change unit of measure of the volumetric flow rate from (Sm3 per day) to (m3 per day) using ideal gas' law?
Because I must find the power required by comrpessor.
Thanks in advance.If I haven't been clear about something tell me.
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
Skrambles
#2
Nov24-10, 03:04 PM
P: 105
Since the gas is being compressed, the volume entering is going to be larger than the volume exiting. Think about it in terms of mass flow rate instead of volumetric flow rate. The same amount of mass has to leave the compressor as came into it.
Also, you shouldn't just assume something is an ideal gas.
exergetic
#3
Nov25-10, 09:41 AM
P: 11
Right,it was just what I was thinking about.My assumption of natural gas as ideal gas was just for approximate its thermophysical proprieties knowing composition of this natural gas.
About this I have also another question:in evaluating power of compression I also need to find the specific work of compression but I should know first the specific heat capacities Cp and Cv (and so them ratio k).
Would it be correct to evaluate Cp and Cv of natural gas as average of the heat capacities of all the component gases weighted on molar fraction?
For example,the mean temperature and pressure of compression are 70C and 16 bar and natural gas is composed in:75% CH4,15% H2S,10% CO2(in volumes,so in moles).
Is it correct to write:
Cpnatural gas(70C,16 bar)=CpCH4(70C,16 bar)*0.75+CpH2S(70C,16 bar)*0.15+CpCO2(70C,16 bar)*0.10
and in same way for Cv?
Register to reply
Related Discussions
Non-standard question about the Standard Model Beyond the Standard Model 6
Small cube/large cube sliding problem with friction... please help quickly :/ Introductory Physics Homework 11
Show R^2 is locally compact with non-standard metric Calculus & Beyond Homework 4
Show R^2 is locally compact with non-standard metric: I need help Calculus & Beyond Homework 2
Metric System vs. Standard System General Discussion 46
