Register to reply
Power factor and frequency change
by DT71
Tags: factor, frequency, power
Share this thread:
DT71
#1
Nov25-10, 10:39 PM
P: 9
240V,50 Hz electrical appliance is rated at 2KW and has a lagging power factor of0.7.
a)Determine the appliance's power factor when it is used on a 60Hz supply?
b)Calculate the supply voltage required to maintain the appliance at its rated power when operated off a 60Hz supply?
2. Relevant equations
p.f.=P/S
S^2=P^2+Q^2 to obtain Q
S=VsI to obtain I
Z=Vs/I to obtain Z
p.f. = R/Z to obtain R
Z^2=R^2+Xl^2 to obtain Xl
Xl=2pifL to obtain L at 50Hz
3. The attempt at a solution
I have done the above then used the value for L in Xl=2pifL at 60 Hz but not sure were to go from here.
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
n.karthick
#2
Nov26-10, 02:31 AM
P: 241
As you have already found Xl at 60 Hz you can find power factor at 60 Hz from value of new Z and R (Note R is unchanged)
Since you know Z and P (rated power) you can find V
DT71
#3
Nov26-10, 03:28 AM
P: 9
Thanks, I get the first section now but I don't see how I can work out the supply voltage using the new Z and the rated power.
DT71
#4
Nov26-10, 03:32 AM
P: 9
should i be using P=V^2/Z
n.karthick
#5
Nov26-10, 03:54 AM
P: 241
Note V^2/Z gives the apparent power S.
DT71
#6
Nov26-10, 03:59 AM
P: 9
I'm confused now, how do I calculate the supply voltage required to maintain the appliance at its rated power at 60Hz.
I have the rated power and the impedence at 60Hz.
n.karthick
#7
Nov26-10, 04:57 AM
P: 241
Hi, you know P and Z, from Z you can find p.f.
From above values you can find S. Once you know S you can find V.
DT71
#8
Nov26-10, 05:24 AM
P: 9
I have worked out the pf to be 0.63
P(rated power) = 2000 w
Z=22.31 ohms
Would it be correct to use P(rated power)= V^2/R as R remains the same to obtain V(supply voltage)
Register to reply
Related Discussions
Power Factor Electrical Engineering 2
Percent change in tension to achieve specified change in frequency Introductory Physics Homework 2
Matsubara frequency convergency factor Atomic, Solid State, Comp. Physics 2
Power Factor Electrical Engineering 5
By what factor would the energy carried by the rope change Introductory Physics Homework 1
