Chemical reactions according to equation
The discussion revolves around a homework problem involving the calculation of the mass of aluminum oxide (Al2O3) produced from a chemical reaction between aluminum (Al) and oxygen (O2). Participants explore stoichiometry, limiting reactants, and molar mass calculations in the context of this chemical reaction.
  • Homework-related
  • One participant states the reaction equation as 4Al(s) + 3O2(g) → 2Al2O3(g) and seeks help in calculating the mass of Al2O3 produced.
  • Another participant prompts the original poster to consider the molar masses of aluminum and oxygen, noting that oxygen is diatomic.
  • A participant calculates the number of moles of O2 and Al, arriving at 0.4 moles of O2 and 3.7 moles of Al, and asks for confirmation of their calculations.
  • One participant advises to determine the limiting reactant based on stoichiometry.
  • Another participant suggests that the mass of Al2O3 produced is 26.52g, but another participant claims this value is too low.
  • A participant explains their calculation process for determining the mass of Al2O3, using the moles of O2 and the stoichiometric ratio from the balanced equation.
  • There is a suggestion to avoid rounding intermediate results and only round the final answer.
  • One participant revises their calculations, arriving at a new mass of 27.17g for Al2O3 and asks for confirmation of their method.
  • Another participant confirms the revised calculation as correct.
Participants generally agree on the method of calculation but there are differing views on the accuracy of the initial mass of Al2O3 produced, with some suggesting it is lower than what later calculations indicate. The discussion reflects uncertainty and refinement of the calculations without reaching a definitive consensus on the final mass.
Participants express uncertainty regarding the rounding of intermediate results and the implications for the final answer. There are also variations in the molar mass used for Al2O3, which could affect the final calculations.
omni
12.8 gr of O Flowed over 100 gr hot Al.
and i got this reactions equation: 4Al(s)+3O2(g)--->2Al2O3(g)
a)how many gr Aluminum oxide Al203 Created through a chemical process ?
i know i need to find the number of moles of oxygen which flowed. and the number of moles of Al present.
for the start.
hope u can help me.
Do what you know you have to do - what is molar mas of aluminum? Of oxygen? Don't forget oxygen is diatomic.
well the molar mass of Al 27g/mol and of oxygen32g/mol
so the number of moles of O2 in this equation is 0.4 moles because i do 12.8g/32=0.4and for All is 3.7 because i have 100g so i do 100/27=3.7 tell me if i Right till here.
thank you.
Correct, now look at the stoichiometry and see which substance will be limiting for the reaction (i.e. run out first).
the number of Aluminum oxide Al203 in grams that Created through a chemical process can be 26.52g?
Any mass of Al2O3 can be created by a chemical process. But in this particular case correct answer is higher, by nearly 3/4 g.
look what i did: is known that 12.8g of O was Flowed over 100 gr hot Al.
so the number of moles of O is n=m/Mm=0.4moles of O.
100g of Al so the number of moles is100/27=3.7 moles.
i used all the O and only used in 0.533 moles of Al.
so to know how many gr Aluminum oxide Al203 Created through a chemical process i am take 0.4 moles of the O and doubler it in the Ratio of the moles ?
like this 0.4*2/3=0.26 moles of Al2O3 and the mass is 102*0.26=26.52g of Al2O3 i did it with the equation: n*Mm=m.
hope you Understand me.
thanks.
Don't round down intermediate results, round down only the final answer.
OK but the way is ok?
and the final answer is the mass of Al2O3 that Created through a chemical process is 102*0.26=26.52g tell me where i Wrong ?
i showed you all the way Because maybe i Wrong somewhere in the way so if you see my way you can know where i wrong.
I already told you what you did wrong.
OK so is need to be like this:0.4*2/3=0.2666 moles of Al2O3 and the mass is 101.93*0.2666=27.17g or if i round down this result i will get 27g YES?
thanks for your Patience really.
Right.
wow i so happy i did sure with ur help so thank you about all the help:)
10K
