Capacitive Start Motor: What Happens After Starting?
  • Thread starter Thread starter paul11273
    Motor
The discussion centers on the operation of a capacitive start motor, which utilizes a capacitor to provide the necessary phase shift for starting under high torque conditions. Once the motor reaches its operational speed, a centrifugal switch disconnects the capacitor and the low impedance winding from the circuit. This mechanism ensures that the motor operates efficiently without the capacitor after startup. The capacitor is essential only during the initial phase to facilitate the motor's rotation.
  • Understanding of capacitive start motors
  • Knowledge of centrifugal switches
  • Familiarity with phase shift in electrical circuits
  • Basic principles of inductance in motors
  • Research the design and function of centrifugal switches in motor applications
  • Explore the role of capacitors in AC motor starting techniques
  • Learn about the differences between capacitive start and inductive start motors
  • Investigate the impact of phase shift on motor efficiency and performance
Electrical engineers, motor design specialists, and technicians involved in the maintenance and operation of capacitive start motors will benefit from this discussion.
paul11273
Someone was talking about a capacitive start motor today, and this caught my interest.
From what I understand, it basically uses a capacitor in order to help get it started. This is used in situations where a large torque is required to get it going.
Here is my question. Once it's started, what happens to the capacitor? Does it stay connected? Is it disconnected via a relay after a certain time period, etc...?
Thanks.
Hi paul11273:
The capacitor is used to phase shift the voltage and provide current to a lower impedance winding. This provides two phase voltage at a higher current to start the motor. The motor is a basic inductance run motor but can not provide the phase shift required at start up. The motor must be rotating to shift the phase.
After the start a centrifugal switch that opens when the motor reaches the desired speed switches the capacitor and the low impedance winding out of the circuit.
Great. Thanks for the explanation. I couldn't find that info on the web.
