Register to reply
Calculate Molarity of Cl- in Solution
by nautica
Tags: molarity, solution
Share this thread:
nautica
#1
Oct2-04, 06:10 PM
P: n/a
A Cl solution with a volume of 13.53 mL was treated with 30.0 mL of Cr3+ solution (containing excess Cr3+) to convert to hexachlorochromateIII:
6Cl- + Cr ----- Cr(Cl)6
The excess Cr3+ was then tirated with 11.85 mL of 0.01280 M (en) according to equation:
Cr + 3en ------------- Cr(en)3
Cr(Cl)6 does not react with en. If 41.35 ML of en were required to react with 20.17 mL of the original Cr3+ solution, calculate the molarity of Cl in the 13.53 mL Chloride sample.
THIS IS WHAT I DID
0.04135 L * 0.01280 M / 3 moles / 0.02017 L * 0.03 L * 6 mol Cl / 0.01353 L with an answer of 0.1164 M Cl- in solution
my problem is - no where did I include the 11.85 mL of the en that was calculated. Do I need to or does this look correct???
Thanks
Nautica
Phys.Org News Partner Chemistry news on Phys.org
Water leads to chemical that gunks up biofuels production
Celebrating 100 years of crystallography
Turning waste from rice, parsley and other foods into biodegradable plastic
poolwin2001
#2
Oct3-04, 03:37 AM
P: 173
You can find Cl- molarity by equating no: moles.
You can find molarity of Cr3+ by:
Then you can find no moles of Cr3+ excess in reaction b/w Cl- by:
Therefore you can find no moles of Cr3+ required to react with CL- and thus no moles of Cl- by:
The dividing by volume you get Molarity.
Central idea is that there is excess Cr3+.
Sorry for long post
regards
nautica
#3
Oct3-04, 10:06 AM
P: n/a
That sounds better. Let me try it and I will post my results.
Thanks
Nautica
nautica
#4
Oct3-04, 10:42 AM
P: n/a
I am still doing something wrong
0.04135 L * .01280 M / 3 moles * .02017 L * .01185 L / .03 L * .0135 L * 6 moles
gives me 1.14 x 10 ^-7 then I divided that by the 13.35 mL to get 8.4 x 10^-6 M of Cl- but that does not sound right.
thanks
poolwin2001
#5
Oct3-04, 11:19 AM
P: 173
I will try to do it in steps so that we can find out mistakes if any easily.
molarity of cr3+=41.35 *0.01280 /3*(20.17) -->(A)
(note:both V are in mL so conversion factor cancels out)
Total no moles in Cr3+soln = (A)*30.0 /1000 -->(B)
No: moles unreacted=11.85 *0.01280 /3 -->(C)
Therefore total no moles unreacted=(B)-(C)
Therefore total no moles of CL- == [(B)-(C)]*6
Molarity of Cl- = [(B)-(C)]*6/.01353
Too lazy to do numericals now .Try this.
nautica
#6
Oct3-04, 11:46 AM
P: n/a
That answer looks better. I am getting 0.022 M of Cl-
chem_tr
#7
Oct3-04, 02:37 PM
Sci Advisor
PF Gold
chem_tr's Avatar
P: 613
I will not contribute to the answering effort, as poolwin2001 did it quite well. I wondered some other thing:
Quote Quote by nautica
It is interesting, since ethylenediamine is a chelator, strong enough to make hexachlorochromate(III) ion to convert [Cr(en)3]3+, at least this is what I thought when I read this thread.
The theoretical reaction should be like this:
[itex][CrCl_6]^{3-}~+~3~en \rightarrow [Cr(en)_3]^{3+}~+~6~Cl^-[/itex]
I have some suggestions though. It is possible that ethylenediamine does not react readily with the labile chromium complex, so a rapid treatment would only chelate the uncomplexed chromium.
Is there anyone to clear this?
Register to reply
Related Discussions
How many mL of 6.0M H2SO4 are required to react with 0.80g of CuO Biology, Chemistry & Other Homework 2
Molarity homework problem Introductory Physics Homework 1
Solution Concentration: Molarity Chemistry 6
Molarity in diluted solution Chemistry 1
Molarity of solution Chemistry 1
