Difference btn flows in a circle vs. rect.
  • Thread starter Thread starter jrnewma
    Circle Difference
The discussion focuses on the comparison of flow characteristics between a rectangular sewer pipe and a circular bypass pipe. The existing rectangular pipe measures 9'x5', yielding a surface area of 45 square feet, while the circular pipe has a diameter of 6 feet, resulting in a surface area of 28.3 square feet. The user questions whether to use the hydraulic diameter for the rectangular pipe, which calculates to a surface area of 32.2 square feet. The consensus is that circular pipes generally facilitate smoother flow and reduce turbulence, leading to more efficient fluid dynamics.
  • Understanding of hydraulic diameter calculations
  • Knowledge of fluid dynamics principles
  • Familiarity with surface area calculations for different pipe shapes
  • Experience with pipe fitting and installation techniques
  • Research hydraulic diameter calculations for various pipe shapes
  • Learn about fluid dynamics and turbulence in piping systems
  • Explore the advantages of circular versus rectangular pipes in fluid transport
  • Investigate best practices for pipe fitting and installation in sewer systems
Engineers, plumbing professionals, and anyone involved in sewer system design and fluid transport optimization will benefit from this discussion.
jrnewma
I am looking to bypass an existing sewer pipe with another pipe. The existing pipe is rectangular, approximately 9'x5'. I am looking to use a circular bypass pipe of 6' diameter. Since the velocity of "water" flowing thru the pipe will be the same then I need to compare the surface areas, correct? The surface area of the 6' diameter pipe is 28.3 SF. Normally to find the surface area of the rectangle I would take l*w to get 45 SF BUT since I am comparing flows do I need to use Hydraulic Diameter of the rectangular pipe and then find the surface area using pi*r^2? Doing it that way I get a surface area of 32.2 SF.
Can I do that? Is that because the flows thru a circular pipe has less turbulence? thanks.
the majority of piping systems specially in liquids using round pipe to make the flow is smoother and reducing eddy losses also because of the hydraulic diameter and also case of pipes fittings it will be easier to work on a circle than a rectang
20K
14K
37K
