New Reply
Calculate the mass of ice with heat transfer / latent heat
Share Thread Thread Tools
Jan21-11, 09:45 AM   #1
Find mi, the initial mass of ice.
Ti = -20
ci = 2093Jkg-1K-1
Ts = +35
ms = 2kg
cs = 837.4Jkg-1K-1
cw = 4187Jkg-1K-1
lf = 3.35x105Jkg-1
S = solid
W = water
I = ice
lf = latent heat of fusion of ice / water
2. Relevant equations
Q=mc[tex]\Delta[/tex]T
Q=C[tex]\Delta[/tex]T
Q=ml
3. The attempt at a solution
For the Solid
Qs = (2)(837.4)(10-35)
Qs = -4.187x104J
For the Water / Ice
Qi = mix(4.186x104)
Q = mix(3.35x105)
Qw = mix(4.187x104)
I don't know where to go from here, I have seen the markscheme however and I am aware that the answer is: mi = 0.100kg
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jan21-11, 10:11 AM   #2
Recognitions:
Homework Helper Homework Help
You've specified everything but the experimental circumstances. What are the initial and final conditions? Do you want to calculate the mass of ice remaining, or the initial mass of ice?
Jan21-11, 10:14 AM   #3
Oops, the Solid is placed on top of the ice. The ice then melts and the final temperature of both the solid and the ice is 10. So basically I'm looking for the initial mass of the ice, before the rock was placed onto it.
Jan21-11, 11:16 AM   #4
Recognitions:
So, the final temperature is 10C. What does that tell you about the the water in the system?
New Reply
Thread Tools
Similar Threads for: Calculate the mass of ice with heat transfer / latent heat
Thread Forum Replies
heat transfer and latent heat Introductory Physics Homework 5
Specific heat capacity, latent heat => ice water steam mixture Introductory Physics Homework 1
Finding mass of ice in latent heat of fusion problem Introductory Physics Homework 6
Calculate latent heat Classical Physics 1
latent heat of fusion/latent heat of vaporization Introductory Physics Homework 2
