How do you analyze interactions in K-space with vector $\rho$ and planes m ± 2?
  • Context: Graduate
  • Thread starter Thread starter Petar Mali
    Planes Vector
This discussion focuses on analyzing interactions in K-space involving the vector $\rho$ and planes defined by indices m ± 2 in a cubic structure. The participants explore the transformation of terms like $\hat{B}_{m,\vec{\rho}}\hat{B}_{m+1,\vec{\rho}}$ into K-space, highlighting the emergence of an unexpected term, exp(i*q), during the transformation. The transition process between states m and m+1 is represented by the transition matrix element V(m,m+1), which also transforms into V(k,q) in K-space. The conversation concludes that with appropriate lattice symmetry, the unexpected term can be absorbed into the transition matrix, allowing for a similar transformation as with the m and m states.
  • Understanding of K-space analysis in solid-state physics
  • Familiarity with cubic lattice structures and their symmetry properties
  • Knowledge of transition matrix elements in quantum mechanics
  • Proficiency in mathematical expressions involving exponential functions and summations
  • Study the mathematical framework of K-space transformations in solid-state physics
  • Learn about transition matrix elements and their role in quantum state interactions
  • Explore the implications of lattice symmetry on physical systems
  • Investigate tight-binding models and their applications in condensed matter physics
Physicists, particularly those specializing in condensed matter physics, quantum mechanics researchers, and students studying solid-state systems will benefit from this discussion.
Petar Mali
If I have cubic structure where plane is define by vector [tex]\rho[/tex] and in [tex]z[/tex] direction I have planes [tex]...m-2,m-1,m,m+1,m+2...[/tex]
and if I have for example
[tex]\sum_{m,\vec{\rho}}\hat{B}_{m,\vec{\rho}}\hat{B}_{m+1,\vec{\rho}}[/tex]
how to go with that in K-space?
If I had[tex]\sum_{m,\vec{\rho}}\hat{B}_{m,\vec{\rho}}\hat{B}_{m,\vec{\rho}}[/tex]
I will say
[tex](m,\vec{\rho})=\vec{n}[/tex]
and then I will have[tex]\sum_{\vec{n}}\hat{B}_{\vec{n}}\hat{B}_{\vec{n}}=\sum_{\vec{n}}\frac{1}{\sqrt{N}}\sum_{\vec{k}}\hat{B}_{\vec{k}}e^{i\vec{k}\cdot\vec{n}}\frac{1}{\sqrt{N}}\sum_{\vec{q}}\hat{B}_{\vec{q}}e^{i\vec{q}\cdot\vec{n}}[/tex]
[tex]=\frac{1}{N}\sum_{\vec{k},\vec{q}}\hat{B}_{\vec{k}}\hat{B}_{\vec{q}}N\delta_{\vec{k},-\vec{q}}=\sum_{\vec{k}}\hat{B}_{\vec{k}}\hat{B}_{-\vec{k}}[/tex]
But what to do in case with m+1. Thanks for your answer!
I am not familiar with these equations, but I try to give some opinions for discussion.
The problem is that there will be an unexpected term, i.e. exp(i*q), if the B(m)B(m+1) are transformed in K-space.
As I learned, B(m)B(m+1) denotes the transition process between state m and state m+1.
The complete formula is usually written in the sum of V(m,m+1)B(m)B(m+1), where V(m,m+1) is the transition matrix element.
When the formula is transformed in K-space, V(m,m+1) are also transformed as V(m,k,m+1,q), or written in V(k,q) for the shortness.
And what i am thinking is that the unexpected term exp(i*q) will be absorbed in V(k,q).
That means you can do the transformation in the case of (m,m+1) just like what you did in the case of (m,m). The difference for the m and m+1 only appears in the transition matrix elements.
Yes, as shawl mentions you get an extra factor of exp(i*q). With the right symmetry in your lattice you will be able to combine the exponentials to end up with something like [tex]\sum_q f(q) B_q B_{-q}[/tex] where f(q) is some real function, probably composed of cosines. This is exactly the sort of thing you get in tight binding, except there you have a creation and annihilation operator on different sites.
  • · Replies 0 ·
