New Reply
Stress in a beam
Share Thread
Feb14-11, 01:18 AM   #1
Stress in a beam
a) This steel beam has a quadratic cross-section (A=100mm2). The force F is 10 kN. Calculate the stress in the rod and show that this stress does not exceed the yield strength of the steel.
2. The attempt at a solution
a)
[tex]\sigma = \frac{10000N}{0.0001m^2}=100 MPa[/tex]
I guess this is right? I'm not sure what the yield strength is. Can I calculate it from the given formulas?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb14-11, 02:10 AM   #2
Recognitions:
Homework Helper Homework Help
The result is okay, but note that [MPa] = [N/mm^2], and not [N/m^2], i.e. you didn't need to convert A into [m^2]. I'm not sure what the expressions in the image mean - are you given a yield strength for steel?
Feb14-11, 02:24 AM   #3
Thanks for replying.
No, nothing else is given. It is a so-called Failure Assessment Diagram (FAD).
New Reply
Similar discussions for: Stress in a beam
Thread Forum Replies
Finding the stress of a beam General Physics 0
Shear stress in a beam Introductory Physics Homework 0
Stress along a Beam Mechanical Engineering 1
Beam Bending & Stress Mechanical Engineering 1
Beam stress Introductory Physics Homework 2
