Linear Algebra: Determine if set forms vector space
The discussion revolves around determining whether a specific set of vectors in R^3, defined by the equations x1 + 2x2 - x3 = 0 and x1x2 = 0, forms a vector space. Participants are exploring the implications of these equations and their relationship to the axioms of vector spaces.
  • Some participants attempt to analyze the closure of the set under linear combinations, questioning how the two equations interact to satisfy vector space properties. Others express confusion about the implications of the second equation and its effect on closure.
Participants are actively engaging with the problem, offering insights into the closure under the first equation while grappling with the implications of the second equation. There is acknowledgment of confusion and a desire for clarification on how to prove or disprove the vector space properties.
There is a noted uncertainty regarding the interpretation of the equations and the conditions under which the set might not be closed, particularly concerning the product x1x2 = 0. Participants are encouraged to consider counterexamples to further their understanding.
0specificity
Determine whether the following set forms a vector space:
{(x1, x2, x3) E R^3 | x1 + 2x2 - x3 = 0 and x1x2 = 0}
The axioms!
I know that the first equation in the set fulfills the axioms for a vector space, since it is of form {x| Ax = 0}. However, I am unsure about the second equation, and how the two must relate in order to form a vector space. Any help would be greatly appreciated!
The axioms!
OK, so you do not need to run through all the vector space axioms to do this. All you need to do is to show that this set is closed under linear combinations. That is, let a and b be scalars, and let x and y be vectors in your set. Then you need to show that ax + by is also in your set.
Also, you seem confused on what {(x1, x2, x3) E R^3 | x1 + 2x2 - x3 = 0 and x1x2 = 0} means. I'm not sure what you mean by {x| Ax = 0}, what is A supposed to be? What {(x1, x2, x3) E R^3 | x1 + 2x2 - x3 = 0 and x1x2 = 0} means is that if you take a vector in R^3, then the first coordinate plus twice the second minus the third is equal to 0 AND the product of the first and second coordinates is equal to 0.
Thank you so much for your help! But I'm still incredibly confused as to how to prove this (I'm sorry I feel really idiotic). I know that for the first equation, if vectors x and y are in that equation, the sum of x+y is also fulfills that equation. In addition, I know that a scalar b times any vector x for that equation implies that bx also fulfills that equation. However, I do not know how to go about using this to see if the whole set is a vector space.
If x1x2 = 0 and y1y2 = 0, x1x2 + y1y2 = 0. However, the vector (x+y) plugged into the equation comes out as x1x2 + y1y2 + x1y2 + x2y1 = 0. Can I assume that (x1y2 + x2y1) = 0?
Ok, so first of all, don't feel idiotic. Linear Algebra is the start of something that is really uncomfortable to most of us, but once you get the hang of it, you'll love it.
So, here is how you prove that your set is closed under x1 + 2x2 - x3 = 0.
Let a and b be scalars, let x=(x_1,x_2,x_3) and y=(y_1,y_2,y_3) be vectors in your set S.
ax + by = a(x_1,x_2,x_3) + b(y_1,y_2,y_3) = (ax_1 + by_1, ax_2 + by_2, ax_3 + by_3).
Now, ax_1 + by_1 -2(ax_2 + by_2) - ax_3 + by_3 = a(x_1) + a2(x_2) -a(x_3) + b(y_1) + b2(y_2) -b(y_3) = (a)(x_1 +2x_2 -x_3)+(b)(y_1 +2y_2 -y_3) = a0+b0 = 0. So, this linear combination satisfies the equation x1 + 2x2 - x3 = 0 and thus your set is closed under that eqation. Now do the same for for other condition.
Thank you so much!
Sorry one more question! I followed the procedure you showed me, and I'm ending up with x_2y_1 + x_1y_2 = 0. Since it was never established that either of the terms are equal to zero, is this set thus not a closed space and not a vector space?
You are correct that it was never established that x_2y_1 + x_1y_2 = 0. And you are correct that this set is not a vector space. However, there is one more thing that you need to do to complete the proof that this isn't a vector space. You need to prove that there are some vectors such that x_2y_1 + x_1y_2 =! 0 (=! is not equals). The best way to do this is to come up with a counter example. Once you do that, you're done.
  • · Replies 23 ·
  • · Replies 18 ·
