| New Reply |
I have a set of numbers, how do I go about proving they form a field |
Share Thread | Thread Tools |
| Feb24-11, 11:10 AM | #1 |
Heres what I know It has to be commutative under addition, which should give symmetry down the leading diagonal, which it does. What else must I show?? Thanks in advance |
| Feb24-11, 11:21 AM | #2 |
I don't quite understand what you are talking about. A "set of numbers"? That doesn't form a field- a single set is not a field. A field is a set of objects (which might or might not be numbers) together with two binary operations called "+" and "*". They must satisfy several laws:
1) They form a commutative group with addition (so, yes, commutative under addition but also associative, there exist an additive identity (0), and every member has an additive inverse. 2) Multiplication is commutative and associative and the distributive law holds. There is a multiplicative identity land every element except 0 (the additive identity) has a multiplicative inverse. I have no idea what you mean by "symmetry down the leading diagonal". Are you referring to a diagonal in the additive or multiplcative tables? If so, that is just saying "commutative" again. |
| Feb24-11, 11:25 AM | #3 |
Yes sorry I didn't word the question very well. I do have two tables for "+" and "*". In the + table is does have symmetry down the leading diagonal, so that is commutative. There does exist a zero, what do you mean by additive inverse?
| New Reply |
| Thread Tools | |
Similar Threads for: I have a set of numbers, how do I go about proving they form a field
| Proving that (Even Numbers)^n = Even Numbers | Calculus & Beyond Homework | 8 | ||
| Prime numbers of given form | Linear & Abstract Algebra | 7 | ||
| Polar form of complex numbers | Calculus & Beyond Homework | 2 | ||
| Proving a Bijection with Catalan Numbers | Set Theory, Logic, Probability, Statistics | 0 | ||
| Proving a property of real numbers | Calculus & Beyond Homework | 10 | ||
