Schrodinger's equation for H atom Some questions
The discussion revolves around the application of Schrödinger's equation to the hydrogen atom, addressing various aspects of the treatment of the nucleus and electron as particles, the implications of using a center-of-mass frame, and the mathematical formulation of their wavefunctions. Participants explore theoretical considerations, assumptions, and potential errors in the modeling process.
  • Some participants discuss the treatment of the nucleus and electron in the context of the center-of-mass frame, questioning whether the mass assignments lead to errors.
  • There is a proposal that the nucleus cannot be described by a Coulomb potential and Schrödinger's equation, suggesting reliance on different quantum field theories.
  • Participants express uncertainty about why the wavefunction for the nucleus is ignored, with some suggesting it is due to the focus on the discrete energy spectrum of the atom.
  • One participant mentions that the full solution involves a product of solutions for fictive particles, raising questions about how to derive the actual two-particle solution from these fictive solutions.
  • Another participant explains that the states of the system can be factored into internal and external states, providing a mathematical framework for expressing the wavefunctions of the particles.
Participants do not reach a consensus on several points, including the treatment of the nucleus, the necessity of including its wavefunction, and the implications of comparable masses for the particles involved. Multiple competing views remain on these topics.
Limitations include assumptions about mass ratios, the dependence on the choice of frame (center-of-mass vs. laboratory), and the unresolved nature of the mathematical steps involved in deriving the full solution from fictive particles.
McLaren Rulez
Hello,
I just finished learning how to solve the Schrödinger equation for the H atom and a few things trouble me.
1) The relative particle, CoM particle treatment: From what I understand, we are solving this for the case where the nucleus is taken to have mass m1+m2 and the electron has mass m1m2/(m1+m2), where m1 is the actual mass of the nucleus and m2 the actual mass of the electron. Am I correct in saying this? And isn't this going to cause an error?
2) Ignoring the nucleus: The wavefunction for the nucleus turns out to be a plane wave. Well, what I don't understand is why we ignore it. Shouldn't we add on that plane wave wavefunction at the end and multiply it to the solution of the wavefunction we get for the electron?
3) Suppose I could not make the first assumption. Let's say I had a system where m1 and m2 were comparable. Then what? How should I proceed?
Thank you for your help.
Just like in classical orbital mechanics, the two-body problem can be viewed in a center-of-mass frame where the problem reduced to an effective one-body problem. This can be done with particles of any mass.
You cannot describe the nucleus by means of a coulomb potential and Schrödinger's equation, but relies on a different fundamental quantum field theory for it's description.
This is normally not different than the Kepler problem in gravitostatics: the nucleus and the electron are replaced by 2 <fictive> particles, one of which is situated in the COM frame.
Not for the nucleus, but for the <fictive> particle situated in the COM frame.
Out of convenience and because we're really interested in finding the discrete spectrum of the atom. A discrete energy spectrum is the trademark of quantization. The observables with completely continuous spectrum are known as <unquantized>.
Indeed, the full solution is a product of solutions (the H-space is a product space anyways).
There's no difference. In this case, the assumption M_nucleus ---> infinity cannot be done, so the full solution must be found.
Thank you, dextercioby.
So now that we have the solutions for the two fictive particles, how do we get the solution for the actual two particles from there?
From a mathematical perspective, solving the problem for the 2 fictive particles is enough, as the 2 Hilbert spaces (real particles vs. fictive particles) are isomorphic.
What dextercioby said above. However, if you want an explicit solution:
The kind of systems you're interested in have states that can be factored in an 'internal' state that describes the relative movement of the two components and an 'external' state that describes the system as a whole:
[tex] \hat\rho = \hat{\rho}_\mathrm{ext} \otimes \hat{\rho}_\mathrm{int}.[/tex]
For a pure state this can be expressed as the product of two wavefunctions:
[tex]\psi(\mathbf{x}_c,\mathbf{x}_r) = \psi_\mathrm{ext}(\mathbf{x}_c)\psi_\mathrm{int}(\mathbf{x}_r)[/tex],
where xc and xr signify the 'centre of mass' and the 'relative' translational degrees of freedom, respectively.
These can be expressed as a function of the translational degrees of freedom of the two component particles m1 and m2:
[tex]\mathbf{x}_1 = \mathbf{x}_c - \frac{\mu}{m}_1\mathbf{x}_r,[/tex]
[tex]\mathbf{x}_2 = \mathbf{x}_c + \frac{\mu}{m}_2\mathbf{x}_r.[/tex]
Where [tex]\mu[/tex] is the reduced mass and xr is defined as x2 - x1.
This allows us to express the wavefunctions as
[tex]\psi_\textrm{ext}(\mathbf{x}_c) \equiv \psi_\textrm{ext}(\mathbf{x}_1,\mathbf{x}_2),[/tex]
[tex]\psi_\textrm{int}(\mathbf{x}_r) \equiv \psi_\textrm{int}(\mathbf{x}_1,\mathbf{x}_2).[/tex]
The Jacobian of this transformation is unity.
The density for particle 'i' will be given by
[tex] \rho_i(\mathbf{x}) = \int \mathrm{d}^3\mathbf{x}_1 \mathrm{d}^3\mathbf{x}_2 \delta(\mathbf{x}-\mathbf{x}_i) \left|\psi_\mathrm{ext}(\mathbf{x}_1,\mathbf{x}_2)\right|^2 \left|\psi_\mathrm{int}(\mathbf{x}_1,\mathbf{x}_2)\right|^2,[/tex]
and its {charge, mass} density by {[tex]q_i\rho_i(\mathbf{x})[/tex], [tex]m_i\rho_i(\mathbf{x})[/tex]}.
The total {charge, mass} density will be given by
[tex]\rho_m(\mathbf{x}) = m_1\rho_1(\mathbf{x}) + m_2\rho_2(\mathbf{x}),[/tex]
[tex]\rho_q(\mathbf{x}) = q_1\rho_1(\mathbf{x}) + q_2\rho_2(\mathbf{x}).[/tex]
  • · Replies 39 ·
  • · Replies 18 ·
