Solve Work Problem: 2.03 mol He, 295 K, 0.350 atm to 1.00 atm
  • Thread starter Thread starter nemzy
    Work Work problem
The forum discussion addresses the calculation of work done on a 2.03 mol sample of helium gas during isothermal compression from 0.350 atm to 1.00 atm at 295 K. The user initially miscalculated the final and initial volumes using the ideal gas law, resulting in incorrect pressure values. The correct formula for work in an isothermal process is W = (nRT)ln(v_i/v_f), which requires accurate volume calculations derived from the ideal gas law. The expected work output is 7.03 kJ, indicating a need for precise values in the calculations.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of isothermal processes in thermodynamics
  • Familiarity with the concept of work in physics (W = -PΔV)
  • Basic logarithmic functions for calculations involving natural logs
  • Review the Ideal Gas Law and its applications in real-world scenarios
  • Study isothermal processes and their implications in thermodynamics
  • Learn about the derivation and application of the work formula W = (nRT)ln(v_i/v_f)
  • Practice problems involving gas compression and expansion to solidify understanding
This discussion is beneficial for students in chemistry and physics, particularly those studying thermodynamics, as well as professionals involved in gas-related calculations and engineering applications.
nemzy
here is the problem:
A 2.03 mol sample of helium gas initially at 295 K and 0.350 atm is compressed isothermally to 1.00 atm. Assume that the helium behaves as an ideal gas.
what is the work done on the gas.
well i know that w=-p*change in volume
i can figure out the final and initial volume using the ideal gas law pv=nrt at the initial and final pressures...so i know what the change in volumeis, but what would the pressure be when calculating the work? i used both 1 atm and .35 atm and i stil get the wrong answer...here is my work
final volume: pv=nrt
p=1.8 atm
n=2.18 mol
r= .0821 liters*atm/mol*k
t=305 k
final volume = .0303 m^3
initial volume: pv=nrt
p=.505 atm
n=2.18
r=.0821 liters*atm/mol*k
t=305 k
initial volume = .108 m^3
change in volume = .0778 m^3
work = -p(change in volume)
the answer is suppose to be 7.03 kj, which means that if my volume calculations were right, the pressure is suppose to be .893 atm?? does anyone know where i went wrong?
Work is defined as integral of pdv => w=Int{pdv}=Int{nRT(dv/v)},where t is constant bacause the process is isothermic => w=(nRT)In{(v_f)/(v_i)} and
v_f/v_i = p_i/p_f.
There are some other problems like"A 2.03 mol sample..." and then you used n=2.18 also "... at 295 K..." T= 305k... and so on
incorrect on the W there...W=(nrt)ln(v_i/v_f)...
