Evaluating an expression when x=infinity
  • Thread starter Thread starter AStaunton
    Expression
The discussion revolves around evaluating the expression -xe^{-x} as x approaches infinity, specifically focusing on the limit rather than direct evaluation at infinity.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the limit of the expression as x approaches infinity, with some questioning the terminology used in the problem. There is discussion about the form of the expression leading to indeterminate forms and the application of L'Hôpital's rule.
The conversation includes various interpretations of the limit, with some participants confirming the use of L'Hôpital's rule and discussing the behavior of exponential functions compared to linear functions. There is a recognition of the complexity of the expression involving infinity and zero.
Some participants express uncertainty about the terminology and the nature of limits involving infinity, indicating a need for clarification on these concepts.
AStaunton
can someone please tell me what is the value of the following expression when [tex]x=\infty[/tex]:
[tex]-xe^{-x}[/tex]
my guess is it is either -1 or 0 or -infinity...
First, be careful of your terminology. You cannot "evaluate a function at x= infinity"- infinity is not a number. What you mean is "find the limit as x goes to infinity" (which, itself, is short for "as x gets larger and larger without bound").'
Since, as x "goes to infinity", [itex]e^{-x}[/itex] goes to 0, this is an indeterminant of the form "infinity times 0". It can be put in the form "infinity over infinity" by writing it as [itex]-x/e^x[/itex] and you can then use L'Hopital's rule.
infinity times 0 = 1 I thought?
I'm thinking this mainly due to the little I know Dirac Delta function..
after using l'hop's rule:
set f(x)=x g(x)=e^x
and f'(x)=1 g'(x)=e^x
I found f'/g'=1/infinity=0 which implies f/g=0..
Can you please confirm this is correct, as my skills with limits is very limited!
you should know that e^x grows very fast and the line y=x grows with slope 1 so it should be easy to picture what lim x--> infinity x/e^x is at x =1000 e^x is about 1.97 *10^434 so this limit is easy to guess
Yes, you are correct. But, in general, "infinity" times zero is not 1...it can be anything, which is why we do not allow it.
