Proving Gauss Theorem for Surface of Curved Charged Conductor
  • Thread starter Thread starter fluidistic
The discussion revolves around applying Gauss's theorem to prove a relationship involving the electric field at the surface of a curved charged conductor. The original poster seeks clarification on the concept of principal radii of curvature and how it relates to different shapes of conductors, such as spheres and cylinders.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of the conductor having two principal radii of curvature and question the necessity of this for different shapes, such as spheres and cylinders. There are discussions about sketching the situation and understanding the geometry involved.
Participants are actively engaging with the problem, raising questions about the definitions and assumptions related to curvature. Some guidance has been offered regarding starting with simpler shapes like cylinders, but there is still a lack of consensus on the interpretation of the radii of curvature and the application of the divergence of the electric field.
There are mentions of external resources that provide different solutions, and participants express confusion about the assumptions made in those solutions, particularly regarding the behavior of the electric field inside the conductor and the treatment of charge distribution.
fluidistic
Use Gauss theorem to prove that at the surface of a curved charged conductor, the normal derivative of the electric field is given by [tex]\frac{1}{E} \frac{\partial E}{\partial n}=-\left ( \frac{1}{R_1}+ \frac{1}{R_2} \right )[/tex] where [tex]R_1[/tex] and [tex]R_2[/tex] are the principal radii of curvature of the surface.
[tex]\int \vec \nabla \cdot \vec E d V= \int _{\partial V} \vec E \cdot \hat n dS[/tex].
The first thing that crosses my mind is to sketch the situation and this is where I'm stuck. Why has the conductor 2 principal radii of curvature? What if it's a sphere?!
Should I sketch the conductor as a "lenslike" solid like we see in geometrical optics sketch?
And by the way isn't the normal derivative [tex]\frac{\partial E}{\partial n}[/tex] instead of the same expression but with a factor of [tex]\frac{1}{E}[/tex]?
hi fluidistic! :smile:
fluidistic said:
… Why has the conductor 2 principal radii of curvature? What if it's a sphere?!
if it's a sphere, the two principal radii are the same (and can be in any direction).
start with the simplest case, a cylinder, so that R2 = ∞ …
then you have the same calculation as for finding E in a cylindrical capacitor …
you'll see that essentially you're finding the formula for ∂/∂n(1/A), where A is surface area within a fixed solid angle :smile:
(and yes, the normal derivative is ∂E/∂n … the phrasing is a little unusual, but they're saying that ∂E/∂n is given by the equation (1/E)∂E/∂n = … :wink:)
Hi tiny-tim,
I still don't understand. By radii of curvature I assue the conductor must have a spherical shape. So a cylinder as you said would do the job but I don't know the "centre" where the radii start. In other words to me a cylinder has only 1 radius of curvature.
But you said its second radius of curvature is infinite, thus I believe it has a plane part? You mean a base of the cylinder? And where does the centre of the radii is?Edit: I just found 2 solutions on the internet of this problem: http://www-personal.umich.edu/~pran/jackson/P505/F07_hw01a.pdf.
It's still not clear to me as what are the radii of curvature.
I prefer the differential approach of page 5 of the PDF. However I do not understand why he takes [tex]\vec \nabla \cdot \vec E =0[/tex], in other words why does he consider a chargeless part of the space when doing the algebra since all the charge of a conductor must lie within its surface when it's in steady state.
I'm also trying to derive the expression [tex]\vec \nabla \cdot \hat n =\frac{1}{R_1}+\frac{1}{R_2}[/tex] without success. Should I get a parametric expression of a sphere and then use some facts/formulae to derive it or there's a simpler way to show it?
no, it can have any smooth shape
(unfortunately, wikipeida is pretty useless on radius of curvature)
every curve in a 2D plane has a radius of curvature, that you're familiar with
on a 2D surface in 3D space, at each point you can cut the surface with planes going through the normal: these give curves along the surface in each 2D plane (ie in each direction at that point) …
the radius of curvature in each such direction is defined as the radius of curvature of that curve :smile:
half-way up an egg, for example, the "horizontal" radius of curvature is small, but the "vertical" radius of curvature is large
and for a cylinder, one radius of curvature is infinite
you can solve the given problem by considering the divergence of ñ, the unit normal vector …
do it first for a sphere, then do the same thing for any two perpendicular directions on a general surface :wink:
i've just seen your edit:
E = 0 inside the conductor, it jumps suddenly at the surface, and then it follows the differential equation given
the .pdf uses a volume just above the surface (as in the picture) :wink:
