What Is the Mass of an Oil Drop Balanced Between Metal Plates?
The problem involves calculating the mass of an oil drop with a charge of one electronic unit, balanced between two horizontal metal plates separated by 1 cm and subjected to a potential difference of 800 volts. The electric field (E) is determined using the formula E = V/d, where V is the voltage and d is the distance between the plates. The equilibrium condition between electric and gravitational forces is expressed as EQ = mg, leading to the equation Q = dmg/V. The discussion emphasizes the importance of considering the characteristics of air in the final calculations.
  • Understanding of electric fields in parallel-plate capacitors
  • Knowledge of equilibrium conditions in physics
  • Familiarity with the concept of electric charge and gravitational force
  • Basic algebra for solving equations
  • Research the characteristics of electric fields in parallel-plate capacitors
  • Study the relationship between electric force and gravitational force in equilibrium
  • Learn about the properties of air and their effects on charged particles
  • Explore advanced topics in electrostatics and charge interactions
Students studying physics, particularly those focusing on electrostatics and force equilibrium, as well as educators looking for practical examples of electric fields and forces in action.
atomicpedals
Two horizontal metal plates are 1cm apart in air. An oil drop bearing a charge of one electronic unit is balanced between the plates when the potential difference between them is 800volts. Find the mass of the drop.
I may need to use some combination of: dV = -E ds, and W = 1/2 eE^2l. But I'm really not even very certain on that.
Really I've got nothing on this one! Any suggestions of which way to look for the solution would be much appreciated.
What's the electric field between the plates of a parallel-plate capacitor? Once you get that, write out the equilibrium condition between the electric and gravitational forces.
Ok, so we have that E=V/d and then that EQ=mg (equilibrium condition), this will then yield Q=dmg/V.
I think I'm playing the right ball-game now, but this seems too simple (and doesn't yield a result that makes sense assuming my arithmetic is correct). Should my final condition take the characteristics of air into consideration?
  • · Replies 26 ·
