| New Reply |
Can you send video over audio for space balloon project |
Share Thread | Thread Tools |
| Apr19-11, 02:59 PM | #1 |
I am working on a space balloon project and I wanted to send video, or pictures, back to earth via walki talki. I wanted to know if this would work; I connect a composite video cable from a camera to the wires of one of the walki talki's microphone wires. Then on the other end take the wires from the second walki talki's speaker and connect them directly to a tv or monitor's video input. Would I get any sort of a picture?
THANK YOU! |
| Apr19-11, 03:05 PM | #2 |
1] Transmission rate - at 300bps (or even 1200bps), you will get about one frame per minute. Either that or your framesize will be about 8x8pixels. 2] Codec - How will they decode the signal on the other end? They have no equipment to convert an audio to a video signal. |
| Apr19-11, 03:34 PM | #3 |
camera ==> walki talki(mic) §§§§ §§§§ §§§§ walki talki(speaker) ==> monitor(video in) |
| Apr19-11, 03:42 PM | #4 |
Can you send video over audio for space balloon projectThe signal is completely different. What you're doing is kind of like taking your TV cable and hotwiring it to your RCA_IN on your stereo, or somesuch. |
| Apr19-11, 03:55 PM | #5 |
| Apr19-11, 04:30 PM | #6 |
Wouldn't an mpeg codec do a lot better than "slow scan TV"? You really have to think digital for this project.
| Apr19-11, 05:22 PM | #7 |
| Apr19-11, 06:04 PM | #8 |
Thanks for the replys guys!
What would be the most simple, cheap, small, and portable option to send pictures or video over audio, like a walki talki or ham. |
| Apr19-11, 06:16 PM | #9 |
What the other posters above are saying is that there isn't a quick and dirty way of kludging something like this together. This sort of project isn't unique--I'd suggest doing a Google search for high-altitude balloon project and seeing what sorts of setups others have used in these sorts of endeavors.
Heck, depending on altitude and drift, an X-11 camera hooked up to a Wi-Fi router and cantenna might be sufficient! |
| Apr19-11, 06:26 PM | #10 |
Perhaps there is another approach?
Why are you restricting the signal to audio bandwidth? The radio carrier signal used in your 'walkie talkie' is capable of supporting a much higher bandwidth than audio, it is not normally done for various reasons, but could easily be done for special purposes like this. You should start with a statemnt of the available carrier. |
| Apr19-11, 06:33 PM | #11 |
| Apr19-11, 07:49 PM | #12 |
If it were possible to modify a walkie-talkie easily for increased bandwidth, the range for video will not be the same as audio. Regardless of which method of encoding is used, a higher bandwidth will reduce the signal to noise ratio in the receiver.
| Apr19-11, 08:08 PM | #13 |
The problem you will face is that all that equipment intended to transfer audio signals filters out all the frequencies not in typical audible range. Voice transfer even more so.
So all the high-frequency components (probably 95% of your signal) will be lost. |
| Apr19-11, 09:22 PM | #14 |
Basically I want to make something like the kenwood VC-H1. CCD => SSTV => Audio out
How hard would it be to make SSTV converter? Could it be done with a single AVR? I don't really care if it is in color or high res, I just want to see where the heck my balloon is. |
| Apr20-11, 10:15 AM | #15 |
I am sure there is free software available to decode an audio SSTV signal.
| Apr20-11, 12:40 PM | #16 |
| Apr20-11, 12:52 PM | #17 |
But wanting doesn't make reality. I did tell you how to do it, and asked a simple question to forward the matter, but you seem to have overlooked this. |
| New Reply |
| Thread Tools | |
Similar Threads for: Can you send video over audio for space balloon project
| Audio/video courses and lectures on chemistry | Other Science Learning Materials | 7 | ||
| Physics audio and video lectures | Math & Science Learning Materials | 24 | ||
| Audio and video lectures on mechanical engineering | Engineering, Comp Sci, & Technology Learning Materials | 1 | ||
| Looking for audio lectures (no video/just audio) | Quantum Physics | 0 | ||
| Looking for some app to capture audio from video | Computing & Technology | 14 | ||
