Why is argon better than a vacuum?
  • Context: High School
  • Thread starter Thread starter eurekameh
    Argon Vacuum
The discussion revolves around the advantages of using argon gas in lightbulbs compared to a vacuum. Participants explore various aspects including the chemical reactivity of gases, structural integrity of bulbs, thermal properties, and the effects on filament longevity. The conversation touches on both theoretical and practical implications of these choices in lightbulb design.
  • Some participants suggest that argon is used because it is non-reactive, unlike air, and question why it might be better than a vacuum.
  • One participant proposes that having pressure inside the bulb allows for thinner glass, reducing manufacturing costs.
  • Another viewpoint is that argon helps to prolong the life of the filament.
  • There is a suggestion that partial pressure from argon can prevent filament materials from evaporating and coating the bulb's interior.
  • Some participants argue that a vacuum could cause the bulb shell to shatter due to atmospheric pressure, while others contest this by stating that bulbs can withstand pressure differentials.
  • A participant mentions that heat transfer in the bulb may primarily occur through convection rather than conduction, prompting further clarification on the mechanisms involved.
Participants express differing views on the structural advantages of argon versus a vacuum, with some asserting that argon is primarily beneficial for preventing filament evaporation, while others emphasize structural considerations. The discussion remains unresolved regarding the optimal choice between argon and vacuum.
Participants note that the effectiveness of a vacuum depends on the quality of the glass and the manufacturing techniques used, suggesting that historical practices may differ from modern approaches. There are also references to the thickness of bulb glass and its implications for pressure tolerance.
eurekameh
Argon gas is used in a lightbulb because it's not reactive, whereas air is. But why is it better than a vacuum?
My guesses:
1) If there is pressure inside the bulb, you don't need the glass to be as strong.
2) The gas will conduct heat away from the filament, cooling it down. (I'm not sure this is a good thing though.)
Prolongs the life of the filament.
A near perfect vacuum would be required. Argon is non-reactive and replaces the air.
Basically, it's a manufacturing cost/benefit ratio type of thing.
Argon infusion is cheaper than vacuum.
Doesn't the partial pressure also discourage the bulb coating and filament materials from slowly evaporating, as they would tend to do in a vacuum?
vacuum will also cause the shell to shatter under the atmosphere
Why would you say that? Bulbs are actually very good at withstanding pressure differentials. In fact, up until about 1913, light bulbs were manufactured with a vacuum (or at least as close as they could come).
Today, most bulbs are pressurized at about 0.7 atmospheres at room temperature to accommodate for expansion as the bulb heats.
Ding ding, DaveC426913 wins. The primary need for an internal gas is not structural but to prevent the filament from evaporating and coating the inside of the bulb with a thin layer of opaque metal. With some partial pressure (ideally from an inert gas so as not to react with the filament), any metal atom that evaporates from the filament will get bounced right back instead of traveling, line-of-sight, to the glass. http://books.google.com/books?id=a6...resnum=1&ved=0CDcQ6AEwAA#v=onepage&q&f=false"
Not trying to be pedantic, just learning physics, and this is a bit of a derail, but wouldn't this heat transfer be primarily convection and not conduction?
Really? Try blowing glass with a perfect symmetry. Then ding it against the table and see what happens if there is a vacuum inside.
Also, let the filament heat the glass up and then hang it from a wall and see what creep is.
There is also diffusion which means a vacuum won't stay long. In 1910 the bulbs were made thick, it was pretty much a jar with a wire in it. Now they're trying to save money and are 400 microns thick in some cases.
The no.1 reason is what Dave said, but I wasn't going to repeat it and was just offering another reason why Argon is good.
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 19 ·
17K
