Effect of a Magnetic Field on a charge
The discussion revolves around the effects of a magnetic field on a charged particle, specifically an electron, as it enters a magnetic field after being accelerated by a potential difference. The problem involves understanding the relationship between the electron's velocity, the magnetic force acting on it, and the resulting motion within the field.
  • Participants explore the relationship between the potential difference, velocity, and magnetic force. There is an attempt to reconcile the use of the magnetic force equation F=Bqv with centripetal force considerations. Questions arise regarding the implications of reducing the potential difference on the electron's deflection.
The discussion is active, with participants examining different aspects of the problem. Some guidance has been provided regarding the relationship between circular motion and the forces involved, leading to a deeper understanding of how changes in velocity affect the radius of the electron's path in the magnetic field.
Participants are working with the assumption that the magnetic field is uniform and that the velocity of the electron is perpendicular to the magnetic field. There is a focus on the implications of changing the potential difference on the electron's velocity and subsequent motion.
noops15
1. Okay so thsi comes from Oct/Nov 05 Physics Paper 4. Question 5 b (ii) 1. The diagram shows a magnetic field into the paper and an electron moving in a straight horizontal line about to enter the field. The question asks what effect is there on the deflection of the electron if the potential difference accelerating the electron intially is reduced.
2. How should I approach this?
3. I assumed that according to F=Bqv, a decrease in v would cause a decrease in F and thus cause a smaller deflection on the electron. But the answer says otherwise because they used the Centripedal Force equation in solving this one. Why is F=Bqv not accepted?
Can you post what they say the answer is? and how they arrived at it?
It says that a decrease in potential difference would decrease v and thus cause a larger deflection. Thats all it says. I'm assuming they used F=mv^2/r to come to that conclusion.
well, if a moving electron enters a magnetic field, it will experience a force perpendicular to it's velocity and hence move in a circle ( F = qv*b) , you agree?
agreed
whenever you have a circular motion, there needs to be a constant radial force ( the centripetal force ) which will point towards the centre of the circle. And if the circle has a radius r, then this force HAS to be equal to
F = mv2 /r
so what that is saying is that, our force here qvB, has to be equal to mv2/r
if it weren't, the electron would not go around in a circle ( of radius r) .
So, we have qvb=mv2/r
or r = mv/qb
Now what happens to r when we reduce v?
ohhhhhh! so simply because its a circular motion therefore we equate the two equations...i see...so yeah then the radius decreases implying the deflection is larger! thanks a bunch!
You can use F=qv*B anytime there is a moving charge in a magnetic field ( its only qvb if the velocity and magnetic field are perpendicular )
in your problem the force the particle experiences is F=qvb, but because this force is always constant perpendicular to the velocity, it becomes circular motion, and for circular motion
Fradial = mv2/r , If your question was, the moon going around the Earth in a circular path , then
GMearthmmoon/r2= mv2/r
or if it was a ball on a string
Tension = mv2/r
basically the condition for any object to move in a circle is to experience a constant radial force of magnitude mv2/r
amazing man, everything I needed to know:) thanks dude!
:smile:
  • · Replies 31 ·
