What is the Enthalpy and Internal Energy Change for a Thermochemical Reaction?
The discussion revolves around calculating the enthalpy change (ΔH) and internal energy change (ΔU) for a thermochemical reaction involving nitrogen and oxygen gases. Participants explore the implications of the reaction being exothermic and occurring at constant temperature and pressure, while also addressing the work done by the surroundings.
  • One participant presents the reaction and asks for ΔH and ΔU per mole of N2(g), noting that 533 kJ of energy is released as heat.
  • Another participant emphasizes the need to correctly write the coefficients for the reaction and suggests that ΔH must be negative for an exothermic reaction, but expresses uncertainty about ΔU.
  • A later reply reiterates the need for correct coefficients and questions how -533 kJ is useful in the problem, while also noting the lack of volume information for calculating moles.
  • One participant states that ΔH can be expressed as ΔH = ΔU + Δ(pV) and questions how to find ΔU without knowing Δ(pV) directly.
  • Another participant mentions the ideal gas law (PV=nRT) but expresses confusion about how to derive U if H is also needed.
  • There is a realization that the reaction occurs at constant temperature and pressure, which raises questions about the implications for ΔU.
  • One participant suggests that for an isothermal reaction, ΔU = 0, since there is no temperature change, and states that under constant pressure, ΔH equals the heat exchanged (q).
  • Another participant implies that knowing q and ΔU would allow for the calculation of work done (w) by the system.
Participants express various viewpoints on how to approach the calculations for ΔH and ΔU, with some agreeing on the exothermic nature of the reaction while others remain uncertain about specific values and relationships. The discussion does not reach a consensus on the calculations or the implications of the given data.
Participants note limitations in their calculations due to missing volume information and the need for clarity on the definitions and relationships between ΔH, ΔU, and work done.
peter444
[tex]N_2_{(g)} + \frac{5}{2}O_2 \longrightarrow N_2O_5 + \mathfrm 533 kJ energy[/tex]
533kJ energy is released as heat
We are given that 101.7g N2 , 102.97g O2 reacted. And this happens at T= 25C and P = 1atm
what is the delta H and delta U for this process per mol N2(g). And how much work is done by the surrounding?
Thanks
(H<- enthalpy , U<- internal energy of the system )
:confused:
Chemistry news on Phys.org
First of all, you need to write the coefficients correctly for the reaction.
Then find the molar amounts of nitrogen and oxygen gas, by using N=14 and O=16 gram/mol.
If a thermal energy is given to the environment, then it is an exothermic reaction, thus [itex]\Delta H[/itex] must be negative, and must have the dimension [tex]\frac {mol}{L}[/tex].
I have no idea what [itex]\displaystyle \Delta U[/itex] is, so another friend will help you in the following days, I think.
i found the number of moles for each gas, but we are not given the volume;As you say [itex]\Delta H[/itex] = [tex]\frac {mol}{L}[/tex]. And how is -533kJ usefull in this problem?
Thanks
H = U + pv, so therefore [tex]\Delta H = \Delta U + \Delta (pV)[/tex]. First off, what is [tex]\Delta U[/tex]?
You can't find [tex]\Delta (pV)[/tex] directly. But for an ideal gas, what is pV equal to ?
For an ideal gas: PV=nRT
but how do I get U, (H=U+PV ) if i also need H
I just realized something, you say the reaction occurs at 1 atm and 25 C, so it is both a constant temperature and constant pressure reaction ?
1 mole of a gas = 24 L (24dm^3)
So you have your mass, so just change that into number of moles, then multiply by 24 L. That will find your Volume.
OK I don't know how you did on your test but
1) For an isothermal reaction for an ideal gas, [tex]\Delta U = C_v\Delta T[/tex] and since presumably [tex]\Delta T = 0[/tex], it follows that [tex]\Delta U = 0[/tex]
2) Under constant pressure, [tex]\Delta H = q[/tex]. If you don't know what [tex]\Delta H[/tex] is, go back and look at the thermodynamics section in your first-year chemistry book.
3) Well now since you know q and [tex]\Delta U[/tex] , you can solve for w, right ?
  • · Replies 19 ·
