Understanding kN in Torque Problems
  • Thread starter Thread starter Enoch
    Unit
The discussion revolves around understanding the unit kN (kiloNewtons) in the context of a torque problem involving a cable supporting a beam. The original poster is attempting to solve for tension in the cable, given mass values and angles, but is confused about the unit conversion to kN.
  • The original poster questions the meaning of kN and its conversion from Newtons, while also expressing uncertainty about their calculations related to weight and torque.
Some participants have provided clarification on the definition of kN and confirmed the conversion from Newtons to kiloNewtons. The discussion appears to be moving towards resolving the original poster's confusion about unit conversion.
The original poster mentions having previously solved similar problems correctly but is struggling specifically with the unit conversion in this instance. There is an attachment referenced that may contain relevant figures for the problem.
Enoch
Unit kN? What is it?
I have a question asking for the tension in a cable that supports a beam. It asks me to find the answer in kN.
What is kN? I know how to solve the problem, but I have no idea what this unit is...What is k?
Figure at the bottom in an attachment.
For the record the question is a torque problem, with given mass values for a beam and two weights in kilograms, as well as the theta value (39 degrees) in tension. I'm assuming I multiply gravity times the mass to get the weight, so that this equation works.
Weight1 X (Length/2) + Weight2 X (Length) + Weight3 (aribitrary distance) = Length X Tsin(39)
This equation has proved correct in a quiz, and it has been explained to me by several profs. However, when I try to apply it to find the answer in kN...I get the wrong answer. Am I converting the weight wrong or is it something else? I realllly need help on this guys :).
kN is KILO Newtons (x10^3) Newtons
in most cases something like m, d, D, preceeding N where N is Newtons for force, then its usually a smaller unit
So if I had an answer like 1054.47 N, it would be 1.05447 kN?
yes that's right
Thanks a lot stunner!
11K
  • · Replies 45 ·
