Simple question about inverting and noninverting op amp amplifiers
The discussion centers on the functionality of inverting and noninverting operational amplifiers (op-amps). It is established that inverting amplifiers connect the input to the negative terminal, resulting in a 180-degree phase shift, while noninverting amplifiers connect to the positive terminal, maintaining the same phase. The key conclusion is that reversing the input terminals would lead to positive feedback and instability, as the loop gain (BA) must remain greater than zero for effective negative feedback. Therefore, the traditional configurations are essential for proper amplifier operation.
  • Understanding of operational amplifier configurations
  • Knowledge of feedback mechanisms in electronic circuits
  • Familiarity with phase relationships in signal processing
  • Basic circuit analysis skills
  • Study the principles of negative feedback in op-amps
  • Learn about the stability criteria for feedback systems
  • Explore the design and applications of inverting and noninverting amplifiers
  • Investigate the effects of phase shifts in signal processing
Electronics students, circuit designers, and engineers interested in understanding operational amplifier behavior and feedback stability in electronic circuits.
learningphysics
Hi. I've always seen inverting amplifiers with the input going to the negative terminal of the op amp, and noninverting amplifiers with the input going to the positive terminal. However I don't see any reason why the inverting amplifier couldn't be used exactly the same way with the input going to the positive terminal, and noninverting with the input going to the negative terminal (but I've never seen it like this). Am I wrong?
Is there a reason the design is the way it is? Thanks.
I am not entirely sure what your question is.
For the - input the phase of the output is 180 degrees from the input.
For the + input the phase is the same.
If you do not care about the phase then either the + or - terminal can be used.
If you do not care about the phase then you do not care about inverting or noninverting.
For a digital NOT gate phase of the output is 180 degrees from the input.
This is the meaning of inverting.
By inverting amplifiers, I was referring to this circuit:http://cnx.rice.edu/content/m0055/latest/
not the inverting terminal. I was wondering if the circuit would work if you had the positive terminal at the top and negative at the bottom. Anyway I think I found the answer, it won't work. The loop gain BA must be >0 to ensure negative feedback. If the terminals are switched BA becomes <0 which means positive feedback and instability.
  • · Replies 78 ·
17K
  • · Replies 33 ·
