How to find the voltage and current of this circuit
The discussion revolves around a circuit analysis problem involving voltage and current calculations for a circuit with resistors. Participants are attempting to find the voltage across specific resistors and the total current in the circuit.
  • Mixed
  • Some participants explore the use of Ohm's Law (V=IR) to calculate voltage and current values. Others question how to determine the voltage across the 20-ohm resistor without knowing its current. There are discussions about the implications of known values, such as total current and voltage drops across certain resistors.
The conversation includes various attempts to clarify the problem and explore different interpretations of the circuit. Some participants express concerns about providing direct answers versus encouraging independent problem-solving. There is a recognition of the need for hints and theoretical background rather than complete solutions.
Participants note the forum's rules regarding homework help, emphasizing that detailed solutions are discouraged. There is a mention of the original poster's request for a detailed solution, which is met with resistance from other members who advocate for a more guided approach to learning.
silvercats
how to find V,I2 and I3 of this.
http://oi52.tinypic.com/10pypw9.jpg
simplified and By putting V=IR
19*8=152
Found the voltage.
But can't find I.
detailed solution expected.
thank you
Please note: I am moving this question to "Introductory Physics", since it is more appropriate there.
19*8=152
Found the voltage.
But can't find I.
What is the voltage across the 4-ohm resistor, and therefore across the 20-ohm resistor? That should help you with finding I2.
Sorry, that is not how this forum works. Please review our forum rules on getting homework help by scrolling down to the section titled Homework Help at our rules page here:
https://www.physicsforums.com/showthread.php?t=414380
4ohm resistor:V=IR
V=8*4
V=32 <<<i think it ok?
How am i supposed to find the voltage of 20ohm one without knowing its current(I)?:o
You have the battery voltage and the voltage drop on the 4 Ohm resistor. What does that suggest?
Given are the total current (8A) and values of the resistors R1(4ohms),R2(20ohms), and R3(60ohms).
V=IR where R is the total resistance and R= R2R3/R2+R3 or (20*60)/20+60= 15ohms
The total voltage is 8A*(15+4)ohms = 152V
Now the voltage across R1 is IR1: 8A*4Ohms = 32V so the "balance" is 120V across R2//R3.
So 120V/15ohms=6A and 120V/60ohms=2A.
Does this help?
It not only helps, it answers the question without the poster having done any work for himself. Not a good learning experience :frown:
The policy here is to provide encouragement, hints, theoretical background, and so forth, so that (hopefully) the querents can work through to, or be guided to, solutions themselves. Just doing the homework for others is frowned upon (it can in fact lead to account cancellation).
Other than that, welcome to Physics Forums, Drohm :smile:
Thanks 'Redbelly98' for answering...!
Yup I didn't do any work.But using this his example ,I did many other questions like this!
Actually gneill,your hint didn't do a good job.Those hints confuse at all.No offense .Thanks for helping
Does this help?
HELL YEAH! thanks.i was able to do more questions like this using your answer.Keep up the good work.Thanks...
lol. why would anyone respond to such an absurd demand?
No offense taken. Let us hope that you have similar templates available for exams.
lol isn't this a violation of forum rules?Talking off topic and rant
yeah let's hope so :wink: :P
At this forum, it's a bigger violation to (A) say you want a detailed solution to a homework problem or (B) provide a detailed homework solution. Did you read the homework help section of our rules yet?
