Restriction of a Linear Transformation
The discussion centers on the existence of eigenvectors within a non-trivial subspace W of a vector space V under a linear transformation T, where T(W) is a subset of W. The lecturer asserts that W must contain an eigenvector for T, regardless of whether the field K is algebraically closed. The proof demonstrates that by starting with a nonzero vector in W expressed as a linear combination of eigenbasis vectors, one can iteratively reduce the number of eigenbasis vectors until an eigenvector is found. This process guarantees the presence of an eigenvector in W.
  • Understanding of linear transformations and vector spaces
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of linear combinations and subspaces
  • Concept of eigenbasis in linear algebra
  • Study the properties of linear transformations in finite-dimensional vector spaces
  • Explore the implications of algebraically closed fields on eigenvalues
  • Learn about the Jordan canonical form and its relation to eigenvectors
  • Investigate the spectral theorem for symmetric operators
Mathematicians, students of linear algebra, and educators seeking to deepen their understanding of eigenvectors and linear transformations in various fields.
dward1996
Given a linear tansformation T of a vector space V (over a field K) with eigenbasis {v_{1},...,v_{n}}, and a (non-trivial) subspace W of V such that T(W) is a subset of W, a lecturer keeps using the result that W will contain an eignvector for T. I can see why this would be the case if the field K were algebraically closed, but how do we know that W will have any eigenvectors for T if K is an arbitrary field?
It follows from the fact that the operator has an eigenbasis. Here's a proof:
W is a nontrivial subspace so it contains some nonzero vector [itex]v=a_{i_1}v_{i_1}+\cdots +a_{i_k}v_{i_k}[/itex], where the [itex]v_{i_k}[/itex]s are some subset of the eigenbasis, all of the [itex]a_{i_k}[/itex]s are nonzero, and [itex]1\leq k\leq n[/itex]. Since [itex]T(W)\subseteq T[/itex], we have [itex]T(v)\in W[/itex]. If all the eigenvalues of the [itex]v_{i_k}[/itex]s are equal, we've found an eigenvector so we're done. If not, we can use the fact that W is a subspace to construct a linear combination of v and T(v), in W, that eliminates one of the [itex]v_{i_k}[/itex]s (concretely, [itex]\lambda_{i_1}v-T(v)[/itex], where [itex]\lambda_{i}[/itex] is the eigenvalue of [itex]v_{i}[/itex]. It's nonzero if the eigenvalues aren't all equal.). So we construct another nonzero vector in W, but with k reduced by 1.
We can now repeat the process. It must eventually terminate, at k=1 if not before. So we've constructed an eigenvector for T in W.
Thanks for that. It makes perfect sense now!
