Need help to find average velocity and pressure drop in duct
The discussion focuses on calculating the average velocity and pressure drop in a duct system with specific parameters. The duct dimensions are 600 mm x 600 mm, operating at a pressure drop of 3 Pa/m over a distance of 87 meters, with a required volume flow rate of 5000 l/s. The average velocity is determined to be 13.88 m/s, leading to a velocity head of 9.83 m of air column. The total fan pressure required to overcome frictional losses is calculated to be 110.63 KPa, resulting in a fan power requirement of 555 kW.
  • Understanding of fluid dynamics principles, specifically velocity and pressure calculations.
  • Knowledge of duct design and airflow characteristics.
  • Familiarity with fan performance metrics and power calculations.
  • Basic proficiency in using formulas for volume flow rate and cross-sectional area.
  • Research "Duct airflow calculations" to deepen understanding of airflow dynamics.
  • Learn about "Fan performance curves" to optimize fan selection for specific applications.
  • Explore "Pressure drop calculations in HVAC systems" for comprehensive duct design.
  • Investigate "Energy efficiency in fan systems" to reduce operational costs.
Mechanical engineers, HVAC professionals, and students studying fluid dynamics who are involved in duct design and airflow optimization.
mchi6aa2
1. the average velocity of the air to meet the required volume flow rate,
2. the pressure a fan needs to produce to overcome the frictional losses in the duct,
2. Relevant Information
Duct size - 600 mm x 600 mm which operates at 3 Pa/m.
The air path is 87 meters from intake to discharge including allowances for grilles, bends and dampers.
The pressure drops per meter are for the required volume flow rate of 5000 l/s. Average velocities in the duct can be calculated by considering the volume flow rate and cross sectional area of the ducts.
Please help. Thanks
Danny
Thats the way I did. I am not sure is it right or wrong:
First , Head required to overcome friction Losses and to maintain
velocity head is to be calculated.
Q= 5000 l/s = 5 m³ /s , A= 0.6 * 0.6 = 0.36 m² , Av . Velocity = Q/A =13.88 m/s
Velocity head = V²/2g = 9.83 m of air coloumn ,
frictional head to overcome by the fan = 3*87=267 Pa
Fan pressure = 1.145 * 9.83 * 9.8 KPa + 267 Pa = 110.63 KPaFan power required = PQ = 110.63 * 5 = 555 Kw
  • · Replies 0 ·
20K
