Properties of electric charges - insulators and conductors
This discussion centers on the properties of electric charges, specifically regarding conductors and insulators. It addresses the behavior of electrons and protons within conductors when subjected to external electric fields, the grounding effect of the Earth, and the uniform distribution of charges within a conductor. Key conclusions include that electrons and protons within a conductor respond to external forces based on proximity and charge interactions, and that the Earth acts as a neutral grounding source, facilitating charge transfer under certain conditions.
  • Understanding of basic electrostatics principles
  • Knowledge of conductors and insulators
  • Familiarity with charge interactions (attraction and repulsion)
  • Concept of electric grounding and polarization
  • Study the behavior of charges in electric fields using Coulomb's Law
  • Explore the concept of electric polarization in materials
  • Learn about grounding techniques and their applications in electrical systems
  • Investigate the principles of charge distribution in conductors and dielectrics
Students of physics, electrical engineers, and anyone interested in understanding the fundamental concepts of electric charges, conductors, and insulators.
joej24
I have some hypothetical questions.
Question 1
There is a conductor with a single electron and proton inside of it. If we try to charge the conductor by induction, we might put a proton close to the conductor. The electron will go towards that proton while the proton in the conductor will be repulsed away. What if the electron and proton inside the conductor bump into each other, thus causing them to become attracted to one another? Does this attracting force and the repulsing force on the proton inside the conductor cause the electron to move away or does the electron inside the conductor still move towards the proton outside of the conductor?
Question 2
Since the Earth is sort of an ultimated source of electrons, when people stand on the earth, do they lose electrons, gain electrons, stay neutral (perhaps from gaining and losing electrons simultaneously), or do the charges in the feet of people just rearrange themselves? The Earth grounds and gains electrons, so does that make it an insulator?
Question 3
Why do positive and negative charges inside a conductor spread themselves uniformly across the conductor?
Alike charged electrons move away from one other while different charged electrons attract one another.
Question 1
I think that the electron/proton pair inside the conductor will stay where it is since the force repelling the electron inside the conductor will cancel the force of the proton pulling the electron towards it. But I also know that electrons move however the heck they want.
Question 2
I think that the charges rearrange themselves because of polarization. That would mean the Earth is an insulator then
Question 3
Is that just the way nature works? I think that the intermolecular electronic forces somehow cancel themselves out
Question 1 is phrased very unusually, but I think I can formulate a response. I think that, because the proton in the conductor is much, much closer to the electron than the proton outside of the conductor, the proton right next to the electron will have the greater effect, and the electron will be more strongly attracted to it. However, the proton will still feel a repulsive force from the outside proton, so, assuming that the proton isn't bound to any other atom or molecule, it would be repulsed away.
Question II: The Earth is electrically neutral. However, because of its size, it is also capable of absorbing charges into it. If a person standing on the Earth is electrically neutral, then there will be no transfer of charges between the Earth and the person. If the person is NOT electrically neutral, then there will be a transfer of charges (think static discharge, but spread out over a second or two). A lightning strike is the most prominent example.
Question III: They spread out evenly because like charges want to get as far away from each other as possible. Because of each particle's equal charge, they naturally put an equal amount of distance between each other in order to reach equilibrium. This applies equally well to positive as well as negative charges.
  • · Replies 29 ·
