Relativistic Momentum Operator
The discussion revolves around the development of a relativistic momentum operator for quantum mechanics, particularly in the context of an infinite square well potential. Participants explore the mathematical challenges associated with integrating momentum probability distributions and the implications of relativistic effects on these calculations.
  • One participant discusses the need for a relativistic momentum operator and presents a proposed form derived from Griffiths's book on quantum mechanics.
  • Another participant suggests that special relativity is not necessary for solving the infinite square well problem and recommends confining the system to a finite box to address divergence issues.
  • A participant clarifies their goal of obtaining the momentum probability distribution from the wavefunction, noting that the distribution is not square-integrable over the real number line.
  • There is a repeated emphasis on the need for the momentum operator to remain unchanged despite relativistic effects, with suggestions that additional modifications may be necessary to achieve square-integrability.
  • One participant presents their derived expressions for the wavefunction and momentum space representation, claiming that their approach resolves previous issues with normalization.
  • Another participant expresses satisfaction with the progress made and inquires about the direction of the work, questioning whether it will be pursued numerically or analytically.
  • A participant indicates a preference for analytical solutions due to computational constraints but acknowledges that numerical solutions may eventually be necessary.
Participants express differing views on the necessity of relativistic considerations in the context of the infinite square well, and there is no consensus on the best approach to achieve a square-integrable momentum distribution. The discussion remains unresolved regarding the optimal form of the momentum operator and the implications of relativistic effects.
Participants highlight limitations related to the convergence of integrals and the need for additional modifications to ensure square-integrability of the momentum distribution. The discussion reflects ongoing exploration of these mathematical challenges without definitive resolutions.
Yitzach
I have in mind to build a game to help teach or demonstrate some concepts in QM and I thought it would be nice to be able to measure momentum. So as a proof of concept before I get too many man hours burned on the project I thought it would be good to do the infinite square well. I managed to get the un-normalized momentum probability out of my math. The only problem with it was that the integral on the real number line did not converge due to it being sinusoidal with a constant additive that gave periodic zeros in the trough. So then I think to integrate between -c and +c. But as this is a classical system, c is not a necessary universal speed limit. So now I would like the relativistic momentum operator. I'm not seeing that available, yet. So using Griffths's book on QM as my resource:
[itex]\hat{p}=\frac{mv}{\sqrt{1-(\frac{v}{c})^2}}[/itex]6.47
[itex]p=-i\hbar\nabla\Rightarrow v=-\frac{i\hbar}{m}\nabla[/itex]cover
[itex]\hat{p}=\frac{-i\hbar\nabla}{\sqrt{1-(\frac{-i\hbar\nabla}{mc})^2}}[/itex]
[itex]\hat{p}=\frac{-i\hbar\nabla}{\sqrt{1+(\frac{\hbar}{mc})^2\nabla^2}}[/itex]
Use:
[itex]\int\Psi*\frac{-i\hbar\nabla}{\sqrt{1+(\frac{\hbar}{mc})^2\nabla^2}}\Psi dx=\left<p\right>[/itex]
[itex]\int\Psi*\frac{-i\hbar\nabla\Psi}{\sqrt{1+(\frac{\hbar}{mc})^2\nabla^2\Psi}} dx=\left<p\right>[/itex]
This doesn't look quite intelligent to me. Does anyone have a better solution to the problem? It would be wonderful if you could provide the eigenfuction for it as well. If this is it, the next trick will be to solve the following equation or an approximation of it:
[itex]\frac{-i\hbar\nabla\Psi}{\sqrt{1+(\frac{\hbar}{mc})^2\nabla^2\Psi}}=p\Psi[/itex]
The relativistic momentum operator is still p = -ih∇, but never mind that. You don't need special relativity to solve the square well! The usual thing to do when your integrals diverge is to put everything in a box of side L.
Perhaps I wasn't quite clear. I have the wavefunction in "configuration" space for the infinite square well which does a very nice job of giving a probability distribution for where the particle should be. I want the probability distribution for the momentum of the particle. Getting the wavefunction in momentum space is reasonable enough. The problem is that it is not square-integrable on the real number line. The following is the momentum probability distribution that I derived 3.54 and 3.56 of Griffths. [itex]|A|^2(-2\cos(\pi n)\cos(\frac{p}{\hbar})+\cos^2(\pi n)+1))[/itex] As it is periodic, the integral over all real numbers does not converge. I would be very surprised if classical QM required that any particle with mass can exceed any speed greater than or equal to that of light. I can make it integrate to a number by requiring that the momentum does not exceed 2.730924×10^-22 Js/m for an electron. But that is relativistic with a gamma of square root of 2. If the momentum operator is unchanged due to relativistic effects, then something else must be added somewhere else to make the distribution square-integrable over the real numbers. Momentum in both classical mechanics and relativity is confined to the real numbers, but relativity restricts the speed to less than or equal to c. Some work with paper and pencil may be required.
That's why you put it in a box of side L.
Box of side L, Yitzach.
Let's (mostly me) try this again. I have the following:
[itex]\Psi_n(x)=\sqrt2\sin(n\pi x)\ x\in[0,1][/itex]
[itex]|\Psi_n(x)|^2=2\sin^2(n\pi x)\ x\in[0,1][/itex]
[itex]\Phi_n(p)=\frac{1}{\sqrt{2\pi\hbar}}\int^\infty_{-\infty}e^{-ipx/\hbar}\Psi(x)dx\ x\in[0,1],p\in\Re[/itex]3.54
[itex]\Phi_n(p)=\frac{\pi n\hbar^2}{\sqrt{\pi\hbar}}\frac{e^{-ip/\hbar}(e^{ip/\hbar}-\cos(\pi n))}{\pi^2\hbar^2n^2-p^2}\ p\in\Re[/itex]
[itex]|\Phi_n(p)|^2=\pi n^2\hbar^3\frac{-4\cos(\pi n)\cos(p/\hbar)+4}{2(p-\pi\hbar n)^2(p+\pi\hbar n)^2}\ p\in\Re[/itex]3.56 filled in for this system.
That looks much better. It should already be normalized, ie that last one should integrate over the real numbers to 1. This time I dropped the sin(n pi) as soon as I saw it and I think it solved a few problems. The other problem was that I had a variable in what I thought was my constant. That should be my solution. Wolframalpha was used for a number of leaps. I would recommend you check my handiwork.
Good, I'm glad you got it to work out. Actually from your original description I thought you were doing it numerically. Is that where you're headed with this?
I think that analytically will be easier on the processor(s) and so I would like as many analytical solutions as possible. But I suspect that eventually, there will be a need for numerical solutions. Numerical is just a little hard on CPU's if you are lacking with that in your computer.
  • · Replies 56 ·
