| New Reply |
Maximums and Minimums |
Share Thread | Thread Tools |
| Jun18-11, 11:24 PM | #1 |
Find the absolute max/min of the function on it's interval. [tex]f(x)=\frac{x^2-4}{x^2+4}[/tex] Interval: [-4,4] 2. Relevant equations 3. The attempt at a solution [tex]f(x)=\frac{x^2-4}{x^2+4}[/tex] I basically want to find all the critical points, so I set the denominator to zero and found a critical point to be where x = 2i, and x = -2i. Then I took the derivative of the function as so: [tex]f'(x) = \frac{2x(x^2+4)-2x(x^2-4)}{(x^2+4)^2}[/tex] Setting the numerator to zero should find where the derivative is equal to zero, but that expands out to this: [tex]2x^3+8x-2x^3+8x[/tex] Which is basically zero anyway. I was going to try to factor out something from the numerator and denominator (if possible) to cancel it out so I could get something, but I thought I would lose solutions doing that. So here is where I am confused? I tried graphing it, thinking that it would just return the line y=0, but my TI-89 just says "not a function or program, error"? edit: fixed |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jun18-11, 11:28 PM | #2 |
Hint Hint: 2 negatives make a positive. Look at your expansion again :)
| Jun18-11, 11:29 PM | #3 |
Ah yeah. Thanks! So the other critical point is 0 then.
| Jun18-11, 11:31 PM | #4 |
Recognitions:
Your algebra is faulty. The x terms don't cancel. And you probably don't care about imaginary solution in the denominator.
| Jun18-11, 11:37 PM | #5 |
[tex]2x^3+8x-2x^3+8x=0[/tex]
from the numerator, works out to be: [tex]16x=0[/tex] x=0 I was not sure what to do with the imaginary solutions, essentially the only critical point found is at x=0 then I would imagine. Leaving me to check the endpoints and x=0 so find the absolutes correct? |
| Jun18-11, 11:39 PM | #6 |
Recognitions:
| Jun18-11, 11:51 PM | #7 |
Alright, I think I got it now. This was the only one in the set of problems that had the possibility of an imaginary solution, and I really wasn't sure if that counted or not.
Thanks for the help. |
| New Reply |
| Thread Tools | |
Similar Threads for: Maximums and Minimums
| Finding local maximums and minimums | Calculus & Beyond Homework | 4 | ||
| Maximums and Minimums | Calculus | 4 | ||
| maximums and minimums | Calculus & Beyond Homework | 5 | ||
| how to find global/local minimums/maximums. | Calculus | 2 | ||
| maximums and minimums | Calculus & Beyond Homework | 7 | ||
