2 Quant. questions (expanding an abitrary state, transition amplitude?)
The discussion revolves around two quantum mechanics questions related to the position operator and transition amplitudes. The first question involves expanding an arbitrary state in terms of position eigenstates, while the second question asks for expressing the cosine of an angle in terms of known eigenstates of a Hermitian operator.
  • Participants explore the expansion of an arbitrary state in terms of position eigenstates, questioning the assumptions about the state being referenced. There is also discussion on how to express cos(A) using the known transition amplitudes and eigenstates.
Several participants provide insights and alternative approaches to the problems. There is an ongoing exploration of the implications of the definitions and the mathematical representations involved. Some participants express uncertainty about the correct interpretation of the questions and the appropriate methods to apply.
Participants note the potential confusion regarding the state being an arbitrary state versus a position eigenstate. There is also mention of additional parts to the questions that may require further clarification and exploration.
ausdreamer
1) The position operator x has a continuous spectrum of engenvalues {x'} with corresponding eigenkets {|x'>}. Expand this state in terms of the position eigenstates.
2) Suppose the transition amplitudes c_a',b' = <a'|b'> are known where {|b'>} are the eigenstates of a Hermition operator. Write cos(A) in terms of {|b'>}.
1) Is this correct? Let the arbitrary state be |x>, then:
|x> = integral(dx' * |x'><x'| * |x>) ?
2) I have no idea how one would write cos(A) in terms of {|a'>}, let alone in terms of {|b'>}??
Any help appreciated!
Normally you would normalize the position eigenstates such that <x'|x> = δ(x-x'), so that you get |x> = ∫ |x'> <x'|x> dx' = ∫ |x'> δ(x-x') dx' = |x>, which is a tautology. I don't quite get the reasoning behind the first question, expand a position eigenstate in terms of position eigenstates? Maybe it was meant momentum eigenstates.
For the second part, use that cos(A) = ½ [ exp(i A) + exp(-i A) ], which is defined by the series expansion of the exponential. Then you can use that cos(A) = cos(A) Σ_{a'} |a'><a'| = Σ_{a'} ( cos(A) |a'> ) <a'| and so on.
For the first i would ask what state though? it doesn't specifically say position eigenstate, is a state referenced somewhere? ro could you assume soem arbitrary state [itex]|\phi> [\itex][/itex]
So we can write:
cos(A) = sum_a' [(cos(A) |a'>) <a'|] = sum_a' [sum_b' [|b'><b'| (cos(A) |a'>) <a'|] ] = sum_a' [sum_b' [cos(A) <b'|a'> <a'|b'>] ] = sum_c [ c^2 * cos(A)],
since <b'|a'> = <a'|b'>* = <a'|b'> = c (given in the question), since A,B hermitian? OR should I do it like this?
cos(A) = sum_a' [(cos(A) |a'>) <a'|] = sum_a' [sum_b' [|b'><b'| (cos(A) |a'>) <a'|] ] = sum_a' [sum_b' [<b'|cos(A)|b'> |a'> <a'|] ] = sum_b' [<b'|cos(A)|b'>]
Both methods and results seem correct, but if I write it in terms of c, then I don't end up writing cos(A) in terms of {|b'>} as it asks...
As for the first question, I forgot to write it all out: "The position operator x has a continuous spectrum of engenvalues {x'} with corresponding eigenkets {|x'>}. The momentum operator p has a continuous set of eigenvalues {p'} with corresponding eigenkets {|p'>}. An ensemble of particles is in an arbitrary state |alpha>. Write out this state in terms of the position eigenstates."
Is the answer to this still just: |alpha> = integral [dx' delta(x-x')* |x'>], like you wrote grey_earl?
Thanks very much for your replies so far, it has been a great help to my study :)
no, that is only if the state is a position eigenstate |x>, replace it with alpha
Ah I see, thanks for that lancedance :) There's more parts to this question that I might post here in case anyone sees this in the next 12 hours or so before my exam I'm studying for :)...
(Continuing on from the arbitrary state |alpha>...) Suppose we make a measurement that selects only particles in the range x'-A/2 to x'+A/2, where A is some small real number. What is the normalized state of these particles immediately after this measurement?
So the new state after the measurement would be (call it beta)... |beta> = integral_lower bounds x'-A/2, upper bounds x+A/2 [dx' |x'><x'|alpha>] = integral[dx' |x'> dirac(alpha-x')]
But have I found the "normalized state"? what do i have to do if i haven't?
Thanks so much for all help so far :)
ausdreamer said:
So we can write:
Before introducing the sum over b', you should apply cos(A) on the state |a'>, that's why I put it in parentesis. Coming from the definition, you get cos(A) |a'> = Σ_{n=0}^∞ (-1)^n/(2 n)! A^(2n) |a'> = Σ_{n=0}^∞ (-1)^n/(2 n)! (a')^(2n) |a'> = cos(a') |a'>. Then write |a'> = Σ_(b') |b'> <b'|a'> and an analog expression for <a'| to get the final result. Note that you cannot change |b'><a'| to <a'|b'>, since the first is an operator, but the second is a number.
No, since <x'|α> is not equal to a δ distribution. You just have |α> = ∫ |x'><x'| dx' |α> = ∫ <x'|α> |x'> dx' = ∫ α(x') |x'> dx'.
:) Any time again!
  • · Replies 0 ·
