What is the remainder when 4101 is divided by 101?
  • Thread starter Thread starter Saitama
    Remainder
The discussion revolves around finding the remainder when 4101 is divided by 101, a problem that appears to be related to concepts in number theory, specifically modular arithmetic and theorems such as Fermat's little theorem.
  • Participants explore various methods to approach the problem, including references to Fermat's little theorem and Euler's theorem. Some express uncertainty about these theorems and seek clarification on their application. Others discuss alternative methods that do not rely on these theorems.
The conversation is ongoing, with participants sharing insights and attempting to clarify concepts. Some guidance has been offered regarding theorems and their relevance, but there is no explicit consensus on the best approach to solve the problem.
Participants mention that the problem may originate from IIT previous year question papers, indicating a potential expectation of familiarity with advanced mathematical concepts. There is also a discussion about the constraints of the original poster's knowledge regarding theorems and notation.
Saitama
Hi!
This is not a homework question but it came in my test.
(1+x)n-1 is always divisible by x.
Only the equation given above came in my mind but i wasn't able to bring it in that form. I am not able to devise other way to solve it. :confused:
Thanks!
Hi Pranav-Arora! :smile:
The easiest way to do this, is with Fermat's little theorem or Euler's theorem (see wiki).
Most applicable here is Fermat's little theorem that says:
For any prime p holds: [itex]a^p \equiv a \mod p[/itex]
(Do you already know about this notation or should I explain? :wink:)Btw, is this IIT stuff or something?
Hi I Like Serena! :smile:
Sorry! But i don't know about Fermat's little theorem or Euler's theorem. :frown:
And yes, it may be from the IIT previous year question papers because most of the time my teacher try to make us solve IIT paper like questions. :wink:
It would be much appreciated if you explain me the notation. :smile:
Well, I don't know what is expected from you here.
Or whether you should know about these theorems already.
Typically it would be first year university mathematics material (algebra).
Actually there is an alternate way to do this for which you do not need to know these theorems. It's just more work.
If we take for instance 43 and divide it by 10, we can also take the remainder of 42 divided by 10, multiply it by 4 and take the remainder again.
The remainder of 42=16 is 6, multiplied by 4 is 24, and the remainder of 24 is 4.
[itex]a \equiv b \mod c[/itex] is about the remainders in divisions.
For instance [itex]10 \equiv 1 \mod 3[/itex] means that if you divide 10 by 3, the remainder is 1.
And it is actually more generic, because you can also say [itex]10 \equiv 4 \mod 3[/itex], mearning that the remainders of 10 resp. 4 when divided by 3 are the same.
I guess I shouldn't explain the theorems as they are probably out of scope for your current class material.
Still, if you're interested, here goes:
Wiki also states Fermat's little theorem without this notation: "Fermat's little theorem states that if p is a prime number, then for any integer a, ap − a will be evenly divisible by p. "
101 is a prime, meaning that it is only divisible by 1 and by itself.
Since 101 is a prime, this means that 4101 - 4 divided by 101 has remainder 0.
I like Serena said:
Well, I'm don't know what is expected from you here.
Thanks for your explanation! :smile:
So if i do it like this, subtract and add 4 to 4101, what i get is this:-
4101-4+4
As you said that 4101-4 is completely divisible by 101, so here +4 is left. Therefore the remainder is 4.
Am i right..?
4101-4+4
Am i right..?
Yep! :smile:
I like Serena said:
Yep! :smile:
Thanks!:smile:
I would also like to know where this Fermat's little theorem is applicable. Would you please tell me? :smile:
Pranav-Arora said:
Thanks!:smile:
It's applicable whenever you have a problem with numbers involving remainders and exponentiation! :smile:
Application in real life is typically in cryptography.
It is used (actually the generalization Euler's theorem) in the RSA encryption technique (http://en.wikipedia.org/wiki/RSA).
This encryption scheme is used world wide for all secure communication across the internet.
When i checked wikipedia, it isn't stated anywhere that "Fermat's little theorem states that if p is a prime number, then for any integer a, ap − a will be evenly divisible by p. " Rather it is stated "if p is a prime and a is an integer coprime to p, then ap−1 − 1 will be evenly divisible by p." :confused:
Are you looking at the same page I did?
http://en.wikipedia.org/wiki/Fermat's_little_theorem
What you mention is the alternate form, which is mentioned in the wiki page right after the text I quoted.
I prefer the version I quoted, since it does not put a constraint on "a".
(And I didn't have to explain what "coprime" means.) :smile:
Yes, i am looking at the same page. When i tried to solve using this statement " if p is a prime and a is an integer coprime to p, then a p−1 − 1 will be evenly divisible by p." then too i got the remainder 4. :smile:
Oops! I didn't noticed it! :biggrin:
And yes i know what a coprime is. :biggrin:
