Power Supply from USB: Get Answers to Your Questions
The discussion centers around powering a digital pen using a USB connection to a PC, exploring the necessary procedures and whether external circuitry is required. Participants also discuss the DTR pin and its potential role in power supply.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant inquires about the procedure for powering a digital pen via USB and whether external circuitry is necessary.
  • Another participant suggests consulting the USB FAQ for additional information.
  • A participant provides details on USB connector pinouts, explaining that pins 1 and 4 supply +5V power and that a peripheral can draw up to 500 mA from these pins.
  • The same participant clarifies that the DTR pin is associated with the PC's serial port, not the USB port, and cautions against using serial port pins for power supply due to unspecified current capabilities.
  • A participant expresses a preference for using USB over serial for powering the device.
Participants generally agree on the use of USB for powering the digital pen, but there is some confusion regarding the role of the DTR pin and its applicability to the USB context.
There are limitations regarding the assumptions about current draw from the DTR pin and the implications of using serial port pins for power supply, which remain unresolved.
Individuals interested in USB power supply for peripherals, particularly those working with digital devices and circuitry design.
kdkdkd
hi,
I want to power a digital pen using a USB connected to the PC. What is the exact procedure for this...as in do i require any external circuitry?
I also heard about this DTR pin which when permenantly enabled, acts as a power supply.
can anyone enlighten me about these things?
thanks.
Computer science news on Phys.org
Perhaps something in the http://www.usb.org/developers/usbfaq/ might help answer your question
Take a look at the USB connector pinouts:
http://www.networktechinc.com/technote.html
The USB connectors have four pins. Pin 1 is +5V, pin 4 is ground; these pins provide +5V power. The USB specification allows a peripheral to draw up to 500 mA from the power pins. Pins 3 and 2 are the differential + and - signalling pins, respectively.
The DTR pin is one of the control pins on the PC's serial port, NOT the USB port. You could potentially use any of the computer's serial port pins for minimal power supply, but it's not a good idea, since they aren't designed for that purpose. There's no specification on how much current it may or may not be able to provide.
If you're designing a USB peripheral, you can use up to 500 mA of current from the USB's power pins. If you're designing a serial-port peripheral, you should really externally power the device.
- Warren
Thanks Warren and imabug.
Guess I'll go for a USB rather than a serial then.
