Converting the diameter for the equation l = RA/rho
  • Thread starter Thread starter vikz
    Diameter
The discussion revolves around calculating the length of an aluminium wire needed to achieve a specific resistance using the formula l = RA/rho. The problem involves converting the diameter of the wire into a usable form for this calculation.
  • Participants are attempting to understand the conversion of diameter to cross-sectional area and how it relates to the resistance formula. Questions are raised about the significance of the variables R, A, and rho, and which of these depend on the diameter of the wire.
Participants are actively clarifying the definitions of the variables involved in the equation and exploring the relationship between diameter and cross-sectional area. There is ongoing inquiry into how to proceed with the calculations based on these definitions.
The diameter of the wire is given as 0.5 mm, and there is a focus on understanding the necessary conversions and implications for the resistance calculation. The resistivity of the material is also specified, which may influence the discussion.
vikz
An aluminium wire has diameter 0.5 mm and resistivity 2.8 X 10-6 Ohm cm. How much lenth of this wire is required to make a 20 Ohm coil?
Please tell me how to convert Diameter 0.5mm? what's the procedure?
After that I can directly apply-
l = RA/rho
l = RA/rho
What do each of your variables signify, R, A, rho?
R = Resistance
rho= Electrical Resistivity of the material of the conductor.
A = Area of cross-section
SI unit of resistivity is Ohm m
vikz said:
R = Resistance
Which of those variables depends directly the radius (or diameter) of the wire?
R is inversely propositional to 1/A
Suppose that d=0.5mm is the diameter of the wire. What is the cross sectional area, A?
  • · Replies 21 ·
12K
10K
9K
14K
