Work, energy with kinetic friction
The discussion focuses on calculating the distance a box slides after descending a frictionless hill and encountering kinetic friction. The initial velocity at the bottom of the hill is determined using the formula v = √(2gh), yielding a result of 11.89 m/s. The work done by kinetic friction is calculated with W = μk * m * g * d, where μk is the coefficient of kinetic friction (0.246). The final distance the box travels before coming to rest is established as 25.8 meters.
  • Understanding of gravitational potential energy and kinetic energy equations
  • Familiarity with Newton's Second Law of Motion
  • Knowledge of the coefficient of kinetic friction and its application
  • Ability to manipulate algebraic equations for solving physics problems
  • Study the derivation and application of the work-energy principle in physics
  • Learn about the effects of different coefficients of friction on motion
  • Explore advanced kinematics, including motion with varying acceleration
  • Investigate real-world applications of friction in engineering and design
Students studying physics, educators teaching mechanics, and engineers involved in motion analysis and friction-related projects.
Bcisewski
Can anyone provide some assistance? I know this comes in two parts, one in locating the velocity, which I believe comes down to v=sq root of 2(9.8)(6.34), however the second part is creating havoc. Any suggestions on part II's formula?
A box slides down a frictionless 6.34 m high hill, starting from rest. At the bottom of the hill, the box slides along a level surface where the coefficient of kinetic friction uk = 0.246. How far from the bottom of the hill does the box come to rest? The final answer will be 25.8m
The First part
[tex]mgh = \frac{1}{2}mv^2[/tex]
The Second Part:
1)
Use the kinetic constant acceleration formula
[tex]v^2 = v_{o}^2 + 2a(x-x_{o})[/tex]
and Newton's 2nd Law on the box where there's friction to find the acceleration
[tex]\sum_{i=1}^{n} \vec{F}_{i} = m \vec{a}[/tex]
2)
Use
[tex]\Delta E = W_{f}[/tex]
[tex]\frac{1}{2}mv^2 = \mu mgd[/tex]
Sure, I can provide some assistance with this problem. First, let's break down the problem into smaller steps to make it easier to solve.
Step 1: Finding the velocity at the bottom of the hill
To find the velocity at the bottom of the hill, we can use the equation v = √(2gh), where g is the acceleration due to gravity (9.8 m/s²) and h is the height of the hill (6.34 m). Plugging in the values, we get v = √(2*9.8*6.34) = 11.89 m/s.
Step 2: Finding the work done by kinetic friction
The work done by kinetic friction can be calculated using the equation W = μk * m * g * d, where μk is the coefficient of kinetic friction, m is the mass of the box, g is the acceleration due to gravity, and d is the distance traveled. Since we are given the values for μk, g, and d, we just need to find the mass of the box to calculate the work done.
Step 3: Finding the mass of the box
To find the mass of the box, we can use the equation F = ma, where F is the force of gravity and a is the acceleration due to gravity. Since the box is sliding down the hill, the force of gravity is equal to the force of kinetic friction. Therefore, we can set the two equations equal to each other and solve for the mass. This gives us m = μk * m * g. Plugging in the values, we get m = 0.246 * m * 9.8. Solving for m, we get m = 1.22 kg.
Step 4: Finding the distance traveled along the level surface
Now that we have the mass of the box, we can use the equation W = μk * m * g * d to find the distance traveled along the level surface. We know that the work done by kinetic friction is equal to the change in kinetic energy, so we can set W = 1/2 * m * v^2 (kinetic energy equation). This gives us μk * m * g * d = 1/2 * m * v^2. Cancelling out the mass on both sides, we get μk * g * d = 1/2 * v^2. Pl
  • · Replies 30 ·
  • · Replies 32 ·
  • · Replies 16 ·
9K
13K
