Mp3 file plays with headphones but not on built in speakers?
  • Thread starter Thread starter Doc Al
    File Headphones
The discussion revolves around an issue where a specific MP3 file plays through headphones but not on the built-in speakers of a laptop. Participants explore potential causes and solutions, including software and hardware considerations, as well as file-specific characteristics.
  • Technical explanation, Debate/contested, Exploratory
  • One participant notes that the issue occurs only with one particular MP3 file, while other files play normally on both headphones and speakers.
  • Another suggests that there may be a short in the headphone jack or a bad connector, recommending to plug and unplug the headphone jack multiple times.
  • Several participants propose reinstalling or updating sound card drivers as a potential solution.
  • One participant speculates that the MP3 file may have been recorded with high input levels but low output, leading to playback issues on the laptop's speakers.
  • Another participant suggests that the file might be corrupted or using an MP3 feature that the laptop's speaker driver does not recognize.
  • One participant mentions the possibility of downloading or ripping another copy of the file to check for corruption.
  • Another participant raises the idea of using Audacity to modify the file to make it more compatible with the laptop's speakers.
Participants express various hypotheses about the cause of the issue, but there is no consensus on a definitive solution. Multiple competing views regarding potential causes and fixes remain unresolved.
Participants mention the possibility of file corruption and differences in audio driver versions between computers, but these aspects remain unverified and are subject to further investigation.
Doc Al
Mentor
mp3 file plays with headphones but not on built in speakers??
This is driving me nuts. I have an mp3 file which plays fine on my PC at work, with or without headphones. But the same file on my home laptop only plays with headphones, not on the built in speakers--I get no audio output. (I have plenty of mp3 files, which all play normally, both with and without headphones.)
How can this be?
Computer science news on Phys.org
How can this be?
Try removing the headphone jack. There must be a short in the jack connection or just a bad connector in the jack. Just plug in the headphone jack a bunch of times.This might help .
If not then please reinstall your sound card drivers or install other compatible drivers for your card .
This weird situation only happens with one particular MP3 file. All my other MP3 files play just fine on internal speakers and headphones.
:confused:
Please try the procedure .
Try updating your sound card drivers.
I am absolutely baffled at why this could happen.
To get this 100% clear, you can listen to other MP3's fine out of your speakers, then when you get to this one, it doesn't play or output sound unless you have headphones?
Try turning your speakers up really loud actually, it might just be that it is quiet.
If it's a bit more complex than that, try downloading(from a different source) or ripping another copy of the file, it could have some weird corruption problems.
Me too!
Exactly.
Nope. And that same file plays just fine out of the speakers on my office PC.
I may try burning it to a CD on one machine just to see if the CD will play on the other.
Very strange!
Have you tried re-downloading the mp3 directly onto the affected computer? Maybe it got corrupted during the download in such a way that only the driver for your speakers is affected.
The other possibility is that that particular song is using an mp3 feature that your speaker's driver doesn't recognize. Do you have the same audio driver versions on your two computers?
How can this be?
One thing that occurred to me is that the mp3 was recorded 'hot'
but with input levels low. The header for the file would indicate
a very loud signal is to be expected whereas the file itself never
reaches it's potential peak levels. Your work pc ignores the high setting for
the relative volumes and plays it anyway with no problem. Your home pc,
not wanting to lose the internal speaker diables playback.
The internal speaker is used as a last resort beep when all
other attempts to indicate a problem is occurring fail.
mathal
I've tried that. No luck.
No idea. Funny, but the laptop giving me the problem is much more recent than the creaking dinosaur on my desktop at work.
mathal
Interesting! Anyway around that?
I use Audacity 1.3 13-beta -(a free application -support it if it works for you) to record my old 78s and 33s. You can import the file and tweak it there and then save it in a more amenable form for your home pc.
mathal
  • · Replies 19 ·
  • · Replies 30 ·
