Understanding Rated Power: Calculating with Voltage Range for Household Devices
  • Thread starter Thread starter keehweelaw
    Power
The discussion revolves around the rated power of household devices, specifically how it is calculated based on different voltage ranges (220V, 230V, 240V) and the implications of these variations for power consumption. The conversation touches on regulatory standards and labeling practices in different regions.
  • One participant questions whether the rated power of 53kW is based on 220V, 230V, or 240V, given the different voltage standards in various countries.
  • Another participant suggests that connecting the device to a 240V system would result in slightly less current consumption, implying that the power would remain at 53kW in both cases, ideally.
  • A different viewpoint argues that connecting the device to 240V would actually lead to a power consumption exceeding 53kW, stating that 53kW is accurate only at 230V.
  • One participant mentions that UK and EU regulations require devices to display a rating plate indicating power consumption at standard voltage, which is now harmonized to 230V across the EU.
  • It is noted that some devices have internal regulators to maintain consistent power consumption across varying input voltages, while others, like resistive heaters, will vary their power draw based on the actual line voltage.
  • Another participant confirms that stating either voltage and current or voltage and power is sufficient for labeling, but advises consulting local electricity regulations for additional requirements.
  • There is a mention of energy efficiency ratings that some products are now required to display, along with the standard information.
Participants express differing views on how rated power is affected by voltage variations, with no consensus reached on whether 53kW is accurate at 240V or only at 230V. The discussion includes both agreement on regulatory requirements and disagreement on the implications of voltage on power consumption.
The discussion reflects varying interpretations of how rated power is determined and the impact of voltage differences, highlighting the need for clarity in labeling practices and regulatory compliance.
keehweelaw
hi all,
am a little confusing with the rated power stated for a product / device. usually we will see product with voltage range 220V - 240V, power 53kW. so this 53kW is calculated by using 220V or 240V or 230V? as different countries have different power supply to the households; i.e. Australia using 240V, China 230V and EU 220V...
If you hook it to 240V system it will consume lightly less current than if you hooked to 220V, in such a way that the power would be 53KW in both case.
Ideally.
nope...in real time it will consume more than 53kW if the device is connected to 240V...and it is 53kW at 230V...
i am just wondering, what is the norm way for people to indicate this on a product?
Under UK and now European law all electrical devices have to carry a 'rating plate' which states, amongst other things, their power consumption at standard voltage.
Since harmonisation the standard voltage throughout the EU is 230 volts.
Some devices, mostly electronic ones, will have internal regulators to draw the same power regardless of the input voltage, within their range.
Other devices such as resistive heaters will draw more or less power according to the actual line voltage.
go well
thanks Studiot.
so i ll consider 53kW at 230V is correct in doing labeling for a product...
Yes indeed.
You can either state the voltage and current or the voltage and power, you do not need all three.
But if this is a real product or an exercise you should consult your own electricity regulations for details of what else needs to be on the rating plate.
Some products now have to show energy efficiency ratings as well.
Please note that responsible manufacturers often add additional non statutory information that common sense dictates.
